Go to Post A Mentor is.. A person you can talk to anything about and trust them to not throw it back in your face in any way shape or form and who will help you as much as they can to deal with the problems and situations in life... - Elgin Clock [more]
Unread 17-01-2005, 23:43
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Ratchet/slip bearing?
I've found over the years that before i should try to make anything i should always see if i can just buy it. Right now what I'm looking for is a bearing that slips in one direction. Think like a ratchet, it will catch in one direction but spin freely in the other. Its what you find in bicycle rear wheels that allows you to pedal but also slip. If anybody knows what the name of such a bearing is I would be quite thankful if you could divulge your knowledge to me. Even better is if you know where i can find one.
~Ian
Unread 17-01-2005, 23:56
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Ratchet/slip bearing?
Typically it is called a one-way-bearing. I'm not sure where to get it. What are you trying to do? Can you use a ratchet, or do you need a bearing.
Unread 18-01-2005, 12:04
~Ian
The term is "clutch bearings" and they are available from McMaster-Carr, p1014 of catalog 109 or just search on their website.
Unread 18-01-2005, 14:49
occra 23.
AKA: ryo
None #1481
how large a one do you need? you can buy small one way bearings for rc cars (oneway pulleys/oneway diffs) in many hobby stores
Unread 19-01-2005, 11:39
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
-Or if you have any of the old bikes around, you could always find away to salvage just the clutch bearing-Or, you can order a nice shiny new one from McMC. I've used them in the past in projects not relating to robotics, and last year when I wanted a unidirectional drive system for the robot ascender, so that it would not backdrive both globe motors, I used a system found on many boat trailers, It was possible to back drive, by pulling the spring loaded latch back - and forcing it all the way up to hit a saftey limit switch (so that the drivers couldnt try to fight the one way mechanism in game) then you could run the system backwards to rewind the spool. What do you have in mind for the clutch bearing? that is if it isnt top secret.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 19-01-2005, 11:45
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
http://www.zxz-bearings.com/onewaybrg.htm
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 20-01-2005, 13:04
AKA: Bradley Rigdon
http://www.smallparts.com/
Search for roller clutches
They have up to 3/4 inside diameter
Looking for 1/2" id flanged bearing .25" thick or less (with flange) Travis Covington Technical Discussion 17 12-12-2004 21:26
bearing help jimfortytwo Technical Discussion 9 01-05-2004 06:20
Bushing v. Bearing VinceT Technical Discussion 14 22-12-2003 19:11
Need A 0.75" ID bearing .DWG Tytus Gerrish Inventor 6 22-10-2003 11:23
Bearing support - Official Mike Martus OCCRA 0 24-09-2002 05:26
