Go to Post Its already begun folks...the Amanda you know is now one of us! mwahahahaha! - Andy Grady [more]
Unread 22-04-2002, 13:34
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Let's see...
standard two joystick tank drive...
left joystick trigger - fire front grabber
right joystick trigger - fire rear grabber
right joystick top - hold to reverse controls
Then we have a box... 2 rocker switches, one for each grabber mechanism... up = grab goal (auto), down = release goal (auto)
Then we have 2 switches for manually releasing a goal, these override everything in case the limit switches are malfunctioning... (*ego* dunno why they would tho, I rigged most of them myself */ego*)
The automatic functions allow it to grab faster, but they're not really needed. Just icing on the cake.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 22-04-2002, 13:40
shelves4 shelves4 is offline
#0643 (Pack 'O Trojans)
shelves4 is an unknown quantity at this point
Send a message via AIM to shelves4
We have two joysticks and some buttons. Works well, easy to use.
Unread 22-04-2002, 16:00
Tom Fairchild's Avatar
Tom Fairchild Tom Fairchild is offline
Nice Guy
Tom Fairchild will become famous soon enoughTom Fairchild will become famous soon enough
Send a message via AIM to Tom Fairchild
Our control box last year was a total mess, so this year I decided to work hard at making a good looking one. One joystick does the driving (if anything I don't want to have to wire a Y cable like last year which is what we would have to do if we wanted 2 joystick) and a switch box does all the rest. Made that out of a transparent blue and white material - looks really cool. For functions, we have 2 two position switches for front and rear latches (which are passive latches, aka, one position is to release, the other is to stay latched or be in the correct position to latch). Three position momentary switches do our elevator, shock absorber manual controlls, and collector height. A regular three position controlls which end of the robot is the 'front' with the middle position being neutral - great while working on the robot and you don't want it to move but still have functionality. Single push button does our dropdown (all automated) and another puts our ball collector at approximately the correct height (pots aren't perfect :-/ ). Finally, one last three position switch does our collector wheel and a two position red on/off switch is a sensor override.
~Tom Fairchild~, who was proud to use all the binary variables in the code w/o using a Y cable.
Former member of Team 122
Unread 22-04-2002, 17:16
Matt Reiland's Avatar
'The' drive behind the drive
Control System for Pegasus 4.0
Our driver gets 1 wonderful Joystick to drive around in slow speed tank steer, pull the trigger to go to full 100% speed tank steer. Press the top button to engage 'Sidestep' which is our version of swerving such that the robot follows the joystick keeping its orientation when the top button is pressed. We added a Pot that selects Joysticks 1-4 and shows the joystick calibration on 4 LED's in a diamond pattern which is handy and works right before the start while the robot is still disabled. The manipulator is 2 more joysticks one to move the goal grabber in-out and release, the other to suck/shoot balls and raise/lower the boom. Calibration turns out to be really important once you pass the 10 ft/sec limit.
Unread 22-04-2002, 21:18
RebAl's Avatar
RebAl RebAl is offline
ISee It When I Believe It
None #0329 (The R.A.I.D.)
RebAl will become famous soon enough
Send a message via ICQ to RebAl Send a message via AIM to RebAl
tank steering with 2 joys (trigger for front grippers), joy for the mouse, box for amp, spear, and side grabber also HUD glasses,
simple but effective
Unread 23-04-2002, 16:42
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
If you have tank steering 2 joysticks is the only way to go... I couldn't imagine driving a tank with 1 joystick.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 23-04-2002, 16:48
PsychoPhil's Avatar
PsychoPhil PsychoPhil is offline
None #0885 (Central vermont Robotics (The Green Team))
PsychoPhil is an unknown quantity at this point
2 joysticks, 2 wheels
We only have to wheels that are driven by the drill motors. The driven wheels are in the middle of the bot so that we can turn on the point...
We have one joystick for each of the two wheels, so 2 joysticks, works best for me as a driver...
so long, Phil
Team #885 (GO VERMONT!)
*2002 Rookie Allstar Award at J&J Regional in New Jersey
*2002 Highest Rookie Seed Award at J&J Regional in New Jersey
*2002 Imagery Award at Canadian Regional (long live the Cowpants)
*2002 "Rally in the Valley" Off-Season Tournament Winning Alliance
*2002 "Rally in the Valley" Off-Season Tournament "Attractiveness in Engineering" Award
Unread 23-04-2002, 17:06
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
We have one joystick for our drive, two buttons for our gear-shift, and two joysticks for our extender arms.
Jeff Waegelin
Monkey controls robot with thoughts Jeff Rodriguez Math and Science 7 13-10-2003 14:29
2003 IRI: A driver's last hurrah or a new rookie driver's experience? Amanda Morrison Off-Season Events 14 23-05-2003 17:39
drivers esellers Rules/Strategy 5 24-01-2003 08:46
Wireless camera ALLOWED as driver's aide? Travis Hoffman Rules/Strategy 7 19-01-2003 02:31
Choice of Drivers archiver 2000 8 23-06-2002 22:36
