Go to Post I'm nervous for those awesome rookie teams that you may not know about much but that just come and do awesome with some fantastic strategy...Rookies rock. - Eugenia Gabrielov [more]
Unread 18-01-2005, 15:56
Anubuss's Avatar
Anubuss Anubuss is offline
AKA: Brian Dixon
FRC #0085 (B.O.B. (Built On Brains))
Anubuss will become famous soon enoughAnubuss will become famous soon enough
Send a message via Yahoo to Anubuss
Spring-loaded claw
Does any body know of a way to create a spring-loaded claw so that it will always remain in a set position unless a servo pulls (or pushes) it back? I'm working on a claw wih this divice in it, but I can't think of a way to do it. Can anyone help?
Unread 18-01-2005, 17:29
westfalia's Avatar
westfalia westfalia is offline
Custom User Title
AKA: Doug
FRC #2234
westfalia is on a distinguished road
Send a message via AIM to westfalia
Re: Spring-loaded claw
Last year I made something like that in order to latch onto a goal automatically when driving up to it, then a servo spun JUST enough to push the opposite end of a lever down in order to let it loose. The way it stayed in the desired position was by a spring. I think if you're looking for advice, one of the most difficult things to do and think about is how to design a device that won't put excessive strain on the nylon gears in the servo motor. But, if you get it working and make it reliable it's very nice. I'll see what i can do in terms of getting a pic of it, but since this thing never got onto the robot (at least my version) it might just as quickly have been destroyed. The thing weighed a TON! Any specific questions?
~Doug
Former 341 team member... Now attending Drexel University and mentoring team 2234!
Unread 18-01-2005, 17:47
Anubuss's Avatar
AKA: Brian Dixon
it wieghted a lot? more so then if a motor like the fisferprice gearbox and all? I've been told i CAN use a motor instead of the servo/spring combo, but my team was afraid it'd weigh too much. Plus, they want the extra motors for the drive train.
Is there a way i could make a spring-loaded pin intangent with a spring-loaded arm? Does a servo have the ability to pull said pin back?
Unread 18-01-2005, 18:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Something attatched to a worm gear will stay in position until the worm is driven, in most cases. The worm gear in the Van Door motor is an exception, it can be backdriven.
Unread 18-01-2005, 19:05
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Use pneumatics with a latching solenoid. Thats what I would do anyway.
Unread 19-01-2005, 15:30
Anubuss's Avatar
AKA: Brian Dixon
I'd like to use pneumatics, but, if I'm only using it for the claw, all that weight from the air compressor is kind of going to waste isn't it?
Unread 19-01-2005, 15:34
You don't have to use the compressor if the tank(s) can give you enough air.
Unread 19-01-2005, 15:48
Anubuss's Avatar
AKA: Brian Dixon
with what I would do with it, the tanks couldn't supply enough pressure for the pneumatics to do what I want, for the number of time I'd want it to do it.
Has anyone created a spring loaded corkscrew that a servo could reset?
Unread 21-01-2005, 15:32
Anubuss's Avatar
AKA: Brian Dixon
I guess not, and if ne ones been working on this problem like me, you might as well just give up. It's do able but it's to sensative. The slightest touch triggers it so, it's not reliagble enough, plus, after so long, the servo starts to give out. Trust me, i nearly fried a servo from a few years ago in testing it.
Adaptative Spring - Driving constraint Daniel_H Inventor 2 03-11-2004 14:33
Spring Compression in Inventor 6? psychoCHIPMUNKK Inventor 1 23-05-2004 13:44
Legality of Spring Loaded Pistons Yan Wang Pneumatics 13 19-02-2004 17:20
Bosch Drill Motor Clutch Spring Dimensions?? aaronbr28040 Motors 3 18-02-2004 19:52
Grey Hindge spring loaded archiver 2000 0 23-06-2002 23:10
