Go to Post Blame it on the programmer. - colt527 [more]
Unread 19-01-2005, 14:39
haverfordfords haverfordfords is offline
haverfordfords is an unknown quantity at this point
Four wheel drive question
Hi all,
For those of you that are creating robots with four wheel drive, how are you accomplishing this? The included gear box only supports two wheel drive and in order to get it to work four wheel drive you need two of part # FRC-2005-112-009.
Innovation First claims that they, "do not sell the transmission gears or sprockets individually. The gear you are looking for is included in the transmission kit. We only sell transmission kits in complete sets."
A complete set would be ridiculously expensive. My question therefore is how do you go around this technicallity to support four wheel drive, OR how did you order the two parts for four wheel drive without buying the whole set, OR does anyone have any extra of these parts?
If anyone could help out this rookie team, we would greatly appreciate it.
Thank you all,
Jason, Team Leader 1656
Unread 19-01-2005, 14:45
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Re: Four wheel drive question
one way to accomplish this would be to drive one set of wheels directly from the gearbox, and drive the other set with a seperate connector chain which is itself driven by those wheels already powered..
this would require adding another sprocket onto each wheel then adding the chain. you may also need to add a tensioner.....as it is a fairly long span for unsupported chain.
also, look through the gallery. teams have been building four wheel drive robots since the start, and none of them have had a ready made two motor gearbox to start with. so you should be several steps ahead!
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 19-01-2005, 14:55
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
We accomplished it by purchasing the ROBOT-SPROCKETS-2005 kit that is $79.95 at http://www.ifirobotics.com/kitbot.shtml
There are a couple of other threads that already discuss this.
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Unread 19-01-2005, 15:57
misterfoo misterfoo is offline
Controls Mentor
AKA: Ken Leigh
#0811 (Cardinals)
misterfoo is on a distinguished road
We used 4x drive last year and it was great, this year we are modifying the setup to have the same. I have not checked with the mech team this week, but I know the conversion is underway from 2 wheel to 4 wheel drive.
If you want to be very simple, you could order a double chain sprocket from Mcmaster. We also converted our wheels to use 5/8 shaft with a similar sprocket and a keyway.
Here is what I found.
http://www.mcmaster.com/
Search for Double-Strand (page 932)
Steel Double-Strand Plain-Bore Sprockets for ANSI #35-2 to #60-2 Roller Chain
Unread 19-01-2005, 16:16
DDRAngelKurumi's Avatar
DDRAngelKurumi DDRAngelKurumi is offline
AKA: Rumi
None #1258 (Celetor)
Team Role: Webmaster
DDRAngelKurumi will become famous soon enoughDDRAngelKurumi will become famous soon enough
Send a message via AIM to DDRAngelKurumi Send a message via MSN to DDRAngelKurumi Send a message via Yahoo to DDRAngelKurumi
We are just ordering more parts, because we are doing 4-wheel drive too.
GOOD LUCK!
Unread 19-01-2005, 16:17
Addict
Please be careful of the advice you are presenting.
The sprockets that came in the kit are custom bored to fit on the kit-tranny shaft. You can't purchase stock sprockets and expect them to fit out of the box. They need to be bored out or at least pressed onto the shaft. This is the 4th time I've had to remind people of this in as many threads, such as this one.
Mark Pettit
Unread 19-01-2005, 16:29
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Originally Posted by haverfordfords
Hi all,
Thank you all,
Jason,
Innovation First DOES sell sprockets individually, but not gears.
Please refer to this page: http://www.ifirobotics.com/kitbot.shtml
Note: you do not need any additional GEARS to make a 4WD system, only sprockets. You can buy 1 sprocket kit "ROBOT-SPROCKETS-2005" and along with the 2 extra wheels and wheel hubs included in the kit be 4-wheelin' before you know it.
The gearbox is easily convertable to a 4WD configuration. In fact, it was originally designed with 4WD in mind. If you simply buy the extra sprockets, you will be up and ready to go in no time.
If you have more problems, do not hesitate to ask,
John
Unread 19-01-2005, 16:31
robolemur1236's Avatar
robolemur1236 robolemur1236 is offline
robolemur1236 can only hope to improve
why cant you make the robot 4 wheel drive with just ordering two more sprockets? add those to the ends of the drive shaft, drop another chain, presto! four wheel drive
being requiring of an interesting team name/mascot/motto that is appropriately geeky and at the same time pleasing to the ear.
Unread 19-01-2005, 16:44
JVN JVN is offline
@JohnVNeun
Refer to attached.
Here are 3 configurations of chain/wheels I sketched up in Paint that may be useful.
Two are 4WD, using different sprocket/chain combos.
One is 6WD.
Just some food for thought.
John
Edit:
Please note, these are just some ideas, there are TONS of ways to reconfigure a drivetrain, and the KOP chassis can be used for quite a few. Every team must decide what seems best.
/Edit
Name:	4WD Options.jpg
ID:	2821  Click image for larger version
Name:	6WD Option.JPG
Unread 19-01-2005, 18:27
caffel caffel is offline
AKA: Charlie Affel
FRC #0423
caffel is an unknown quantity at this point
Use MSC Direct or McMaster Carr or KartWorld.com.
Buy # 35 chain plate sprockets (no hub needed).
Drill a circle of holes using the wheel flange as a template.
Bolt directly to the wheel flanges.
Requires a chain tensioner or having one shaft movable to keep tension on the chain.
Charlie, Team 487
Charlie Affel,
Mentor 423
Unread 19-01-2005, 19:02
President, VEX Robotics, Inc.
No! You can not use just plate sprockets. The #35 chain will rub against the wheel if you do not have the hub on the sprocket. The hub (1/4" hub projection) on the kit sprocket is the shortest I recommend and still have the chain be a safe distance away from the wheel.
-Paul
Unread 19-01-2005, 19:03
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
-Paul
Then simply add a spacer on your bolts.
Team 1257
Unread 19-01-2005, 19:06
JVN JVN is offline
@JohnVNeun
I recommend the following spacer, if you take this approach.
It will put your chain out a safe distance from the skyway wheel.
The OD of the spacer will fit into the hex indents on the wheel hub.
Spacer – 10-32 Screw, 5/16” OD, 9/16” Length
McMaster Part No. - 94639A786
John
Unread 20-01-2005, 00:53
Originally Posted by JVN
Jason,
John
Thank you everyone for your great suggestions!!! So if I read this correctly, all we need is ROBOT-SPROCKETS-2005 and that has the parts we need? AWESOME! Please just confirm this and we will order that right away. Thanks again!
Unread 20-01-2005, 01:16
JVN JVN is offline
@JohnVNeun
That's affirmative.
With the "ROBOT-SPROCKETS-2005" Kit ($80 + shipping) you can construct the 4WD configuration I show on the right in my above post.
Isn't that awesome?
Less than $100 for a fully working 4-motor, 4WD base.
It's a brave new world.
JV
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Quatro 4 wheel drive ufa_mike Control System 2 15-04-2004 02:30
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
XP Hard Drive Space Question Raven_Writer Chit-Chat 13 07-08-2003 16:38
