Go to Post "What connection is the most vital to the success of your robot?" The one between the drivers brain and hands, and the one between the coaches brain and mouth. None of the other ones matter if those two don't work. - dlavery [more]
Unread 18-01-2005, 16:53
Fe_Will's Avatar
Fe_Will Fe_Will is offline
AKA: Will
FRC #0955 (CV Robotics)
Fe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud of
pic: Team 955's take on 4 speeds (back)
"It is the mark of an educated mind to be able to entertain a thought without accepting it." -Aristotle
Unread 18-01-2005, 16:57
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: pic: Team 955's take on 4 speeds (back)
Looks very nice. Great job.
one question, How are you planning on securing the Fisher price motor? is it just hanging there? or is there something I am missing?
Another thing (probably i cant see it just because of the plates), is there any shaft inside that transmission that are going through 3 bearings? If yes, then its bad.
great job on keepinging the transmission about 5 pounds.
-Arefin.
Edit - I am not an Engineer YET. But from my understanding of making a transmission, I would say, try to make the transmission and put everything (gears, motors, shafts, bearings, bushings) between 2 plates and not 3.
Unread 18-01-2005, 16:58
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
-Arefin.
I was just going to say the same thing. Plus the CIM. Two easily corrected problems that could spell huge trouble if you don't do anything.
2001-2004: Team 100
2006-Present: Team 254
Unread 18-01-2005, 19:25
Fe_Will's Avatar
AKA: Will
-Arefin.
-That shaft must be supported on all three points, hence the three bearings...
-Our inventor guy was just too lazy to add the motor mounts.
-Can't reveal everything
Unread 18-01-2005, 19:29
AKA: Ari
I am not going to support you on this one, just because of the fact the shaft will bind if you are runing it between 3 plates with 3 bearings. But overall design is good. I still would like to know how are you mounting the motors.
-Arefin.
Unread 18-01-2005, 19:35
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Having a shaft supported by three bearings is like an over-constraint. The only way you should even consider doing this is if you are certain you can keep tolerances to around .0004 (yes 4 ten-thousandths) and trust me, that is not an easy thing to do, even on a CNC.
Will it work with three bearings on a shaft? Yes. Will it bind and cause a loss of efficiency? Yes.
Unread 18-01-2005, 19:45
Roland's Avatar
Roland Roland is offline
Post-A-Holic
#1466
Team Role: Webmaster
Roland is infamous around these partsRoland is infamous around these partsRoland is infamous around these parts
Is there really much use for a 4-speed transmission this year? Surely there's not going to be so much variance in field conditions that you'll want or need to shift that much on a field as small as this one...
Unread 18-01-2005, 19:58
Cory's Avatar
AKA: Cory McBride
The field is longer than last year and there were two teams that used 4 speed transmissions. It's up to each team's personal preferences whether or not the added complexity and time is worth the advantages
2001-2004: Team 100
Unread 18-01-2005, 20:23
Roland's Avatar
Post-A-Holic
#1466
Of course it's up to teams to decide what to build. I'm just wondering how often multi-speed gearboxes are used in competition on the field. I've never driven a robot with a multi-speed gearbox, nor have I spoken at length to drivers on teams with multi-speed gearboxes. I simply want to hear honest opinions about what good a gearbox like 955's here will do this year. I understand how plenty of experienced teams would do it for the cool factor alone, but I want to hear what real drivers - or mechanical designers, even - have to say about multi-speed drivetrains in practice.
Unread 18-01-2005, 20:27
Cory's Avatar
AKA: Cory McBride
Well, I've driven a couple shifting robots and 2 single speed robots.
One of the single speed robots was very slow, one was very fast.
Of them all I'd rather drive the two shifting robots. You have power when you need it, and speed when you need it. With the single speed ones there was always moments when I either wished I had more speed, or more torque, respectively.
2001-2004: Team 100
Unread 18-01-2005, 22:34
Fe_Will's Avatar
AKA: Will
Alright, wrong thread dude. Get a clue and look at the other posts perhaps?
By the way, I'd like to see what you have to say when our robot is on your side of the field in five seconds running defense and using our insane torque to push you back to the starting point.
We're working on ideas for not having three bearings if you'd like to add some helpful advice. Thanks for the input, but there are multiple threads on the subject you brought up. It seems like every tranny post degrades into a discussion of whether or not multiple speeds are a necessity.
P.S. We will also be mounting motors on a fourth plate, just in case you all are really curious.
Unread 18-01-2005, 22:54
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
The easiest solution is just to drop the middle bearing. And 4 plates? Seem's kind of a lot, how thick are these plates? Because judging by the CAD rendering, they seem to be a lot thicker than necessary.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 19-01-2005, 18:40
cheezer cheezer is offline
grunt
AKA: justin
#0955
cheezer is an unknown quantity at this point
the plates on the tranny are 3/8 inch thick
Unread 19-01-2005, 19:05
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
why so thick? and what material are they made of?
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 22-01-2005, 01:35
Fe_Will's Avatar
AKA: Will
They are aluminum. We are known for our "tanks", it'll be built to last.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
Kettering University Rookie Robotics Team Alexander McGee General Forum 23 22-12-2004 09:13
Question of the Week!!! (9/3/04) Andy Grady General Forum 36 19-09-2004 20:13
Disqualifications archiver 1999 13 23-06-2002 21:53
