Go to Post All a team needs is someone to believe in them. - JohnBoucher [more]
Unread 19-01-2005, 17:43
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Spring Return Pistons' Legality
Are single-action spring return pistons legal for use on robots this year? Our pneumatics leader is unsure and I have yet to find a ruling against it. Thanks in advance.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 19-01-2005, 20:08
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Re: Spring Return Pistons' Legality
i have asked through the FIRST Q & A board specific pneumatic questions
all their responses say to refer to R90 and the flow chart
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 19-01-2005, 20:21
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
The only pistons that may be used are those available from the kit, and identical models (see Rule <R90>). These are documented on Page 19 of the 2005 Pneumatidcs Manual. That list does not include single-action spring return pistons. So, I would think the answer would have to be "no."
Unread 19-01-2005, 20:25
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Originally Posted by FRC 2005 Manual, SECTION 5 THE ROBOT
<R90> There is no limit to the number of solenoid valves, air cylinders, pressure regulators, and connecting fittings you may use on your robot. They must, however, be “off the shelf” pneumatic devices rated by their manufacturers for pressure of at least 125psi. Besides the “free” pneumatic components listed on the Pneumatic Components Order form, you may purchase additional air cylinders or rotary actuators, however, they must be identical to those listed on the Pneumatic Components Order form , and obtained from a Bimba or Parker Hannifan distributor.
Please refer to the highlighted parts, pretty much its all ready in plain english right there. If the cylinder you want to use is on the pneumatics order form (last page of the 2005 FRC Pneumatics manual) then you can buy it and use it, if its nto there, its not legal to use.
-Michael Dessingue
Adaptative Spring - Driving constraint Daniel_H Inventor 2 03-11-2004 14:33
NEW Spring Off Season in NJ Wayne C. Off-Season Events 25 11-06-2004 10:21
Spring Compression in Inventor 6? psychoCHIPMUNKK Inventor 1 23-05-2004 13:44
Legality of Spring Loaded Pistons Yan Wang Pneumatics 13 19-02-2004 17:20
Bosch Drill Motor Clutch Spring Dimensions?? aaronbr28040 Motors 3 18-02-2004 19:52
