Go to Post we need a diverse team, and until we can welcome someone that's not a nerd, I don't think we're really successful in our recruiting. - JBotAlan [more]
Unread 18-01-2005, 19:49
JMH's Avatar
JMH JMH is offline
AKA: Jereme Henson
FRC #1370 (Blue Charge)
JMH is an unknown quantity at this point
Send a message via AIM to JMH
problems with G22
There appears to be a lot of grounds that end at terminal G22. Is this to much load for the terminal?
Please advise us as to whether other ground terminal can be used as well.
Unread 18-01-2005, 23:56
Electrical Engineer
Rookie Year: 1995
Re: problems with G22
Please read: http://www.ifirobotics.com/docs/brea...005-revnc0.pdf
If you have further questions, please post and we will try to help.
Mike Betts
As easy as 355/113...
Unread 19-01-2005, 20:52
JMH,
The drawing reads G1-G22 or G1 through G22. These terminals are intended for a single return per terminal. It is best that the device that has it's positive lead connected to a breaker terminal, have it's negative lead connected to the same marked return terminal. i.e. Connect a spike to breaker 15, connect the negative terminal of the spike to G15.
PC problems. . . opnickc IT / Communications 5 12-01-2005 16:53
Robot Rodeo - fixing control problems Gary Dillard Off-Season Events 7 26-10-2004 00:46
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Joystick problems archiver 2001 3 24-06-2002 02:40
