Go to Post Still waiting for the "GDC Member" position to open up. Got my resume all set for that one. - Tetraman [more]
Unread 19-01-2005, 22:46
BadKarma's Avatar
BadKarma BadKarma is offline
gfxcore
AKA: kerPLUNK!
FRC #0011 (Mount Olive Robotics Team)
BadKarma is on a distinguished road
Send a message via AIM to BadKarma
skinning and texturing
hey, any suggestions for how to flatten a hi-poly human mesh to be used to create the skin/texture?
...and you shall shed tears of scarlet...
Team 11 2005 Awards
NJ Regional Chairman's Award
Palmetto Regional Judge's Award
Palmetto Regional Autodesk Visualization Award
Stevens Institute of Technology - Class of 2009
Unread 19-01-2005, 22:56
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: skinning and texturing
I think this is a fairly common task. There are numerous tutorials all over the web. Start here: http://www.google.com/search?sourcei...nning+tutorial
Team 1257
Unread 20-01-2005, 11:23
Baden3DMAX13's Avatar
Baden3DMAX13 Baden3DMAX13 is offline
IUPUI Student/ 3D Animator
None #0393 (Full Metal Jackets)
Baden3DMAX13 is on a distinguished road
Send a message via AIM to Baden3DMAX13 Send a message via MSN to Baden3DMAX13 Send a message via Yahoo to Baden3DMAX13
you could apply the texture to your model and use a UV Unwrap on it and take each peice of the mdel and put it on the texture map where it's supposed to be.
Out of all the things I've lost, I miss my mind the most. - Ozzy Osbourne baby!!!
Fiat 500 (WIP) <~~Check It Out!!!!
Unread 20-01-2005, 20:36
BadKarma's Avatar
gfxcore
AKA: kerPLUNK!
ok, i have a high poly human done. its one mesh and the only thing i found about how i could export the mesh as a .bmp or .jpg to texture would be 2 seperate the mesh into about 20 seperate parts, map/unwrap the new parts, then find a plugin which will export that to a picture file. u guys think this would be the easiest way to accomplish this? suggestions, tutorials, and help would be extremely appreciated.
Team 11 2005 Awards
Unread 21-01-2005, 15:11
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
yes... thats probably the best way to do it... you cut off the arms, legs head, feet hands face etc... then apply a seperate UV Maping ( i.e cylinders for the arms... etc...) and then use that to create a bit map then recombine the meshes and weld the vertices w/in 0.0 of eachother
