Go to Post Don’t choose your hero because they will just teach you with their abilities, but also because they will also teach you with their mistakes. - Ken Leung [more]
Unread 19-01-2005, 07:07
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Kit Gear Box in Inventor?
I downloaded the kit gear box inventor file, but for some reason it is a yellow transparent object, it doesn't show it as a solid. Also when I try to put it in an assembly it shows it in the list of parts that you have added but you can't actually see it. Help please?
David Guzman
Unread 19-01-2005, 09:49
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Re: Kit Gear Box in Inventor?
There is a button immediately to the right of the "Look At" button, which selects between solid faces ("Shaded Display"), transparent parts ("Hidden Edge Display"), or "Wireframe Display." Perhaps this button is not set to "Shaded Display"?
A screenshot would be helpful in diagnosing your problem. Good luck!
Unread 19-01-2005, 11:44
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
It sounds like you are seeing the part modeled as surfaces, rather than solid. Are there any options in the Styles pull-down on the right side of the menu bar? As Greg noted, a screen shot would be helpful.
I've attached an example of a revolved surface - is this something like you're seeing?
Pete Kieselbach
Unread 19-01-2005, 21:43
AKA: Dave
Here is a picture of the problem that i'm having. I'm kind of new with inventor so maybe it has a very simple solution.
Now for the buttons, I know im kind of slow but I can't find them.
Thanks for all the help
David
Unread 19-01-2005, 21:56
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
You may want to include a slightly larger screenshot so that we might, y'know, be able to see something
--Madison--
...down at the Ozdust!
Unread 19-01-2005, 22:24
AKA: Dave
lol, sure i can do that, i think.
Unread 19-01-2005, 22:49
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
If any one has the KOP Gear Box in Inventor 8, can it be saved to a previous version and uploaded somewhere for us old folks using version 7. I tried to import the IGES, but it locks up my computer - Arrrggghhh!
Unread 19-01-2005, 23:41
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
The screenshot looks to me the same way that Pete's gearbox is, but it looks like the solidity on the assembly is there. Try opening up all of the parts and try doing what Pete said.
-Daniel
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 20-01-2005, 12:50
petek's Avatar
What would Dave do?
Have you tried the STEP files on IFI's site ?
Originally Posted by David Guzman
I downloaded the kit gear box inventor file, but...
Where did you download this file from? It shows as a part file (.ipt) in your screenshot, but the download from IFI should be an assembly (.iam). You might try downloading again from the link above.
Pete Kieselbach
Unread 20-01-2005, 22:12
AKA: Dave
Thumbs up Re: Kit Gear Box in Inventor?
Thanks to every one for the help. I think that what happened is that at first i downloaded the IGES file so it came out like that but now that i did the parts and the assmbly it works fine.
Thanks Again!!!!
David
Unread 21-01-2005, 10:22
Doug G's Avatar
Coach / Teacher
Yeah, but it lock's up my computer as well. Strange, it's not like my computer is junk either, P4, 2.4GHz, 700+MB RAM, so still I say, ARRRGGGHHH!!
Unread 21-01-2005, 12:36
petek's Avatar
What would Dave do?
When you say "it locks up your computer" does it actually lock up or crash? On my Xeon 1.7 GHz, some of the larger STEPs take over a minute to convert.
Pete Kieselbach
Unread 25-01-2005, 14:38
fusion fusion is offline
fusion is an unknown quantity at this point
meaby you have something on this. i've made a program for school that draws gears up to 140 tooth!
http://inventor.iconrate.net/tandwiel.ipt
credits go to myself and www.inventor.co.nr
Unread 25-01-2005, 19:31
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Only a minute? my 2GHz machine took a lengthy 20...
Make sure when it does import you immediately save it to Inventor formats, they open really fast in comparison.
Matt Krass
Unread 26-01-2005, 10:58
hopkins's Avatar
hopkins hopkins is offline
AKA: Sarah
FRC #1025 (IMPI)
Team Role: Driver
hopkins will become famous soon enoughhopkins will become famous soon enough
Send a message via AIM to hopkins
David Guzman
Exactly how can i get the kit gear box inventor file? Also, does it come already assembled. Or piece by piece?
We are finding the gears extremely hard to draw because of the lack of dimensions we can find.
We especially need the housing and gears.
Given Gear box shematics rcubes85 Technical Discussion 2 14-01-2005 23:35
Drill motor in a Dual Motor gear box MBosompra Technical Discussion 3 16-01-2004 21:37
Inventor drawings of parts from kit patrickrd Inventor 1 11-01-2002 14:16
Inventor and Virtual Kit of Parts Torchin Inventor 1 09-01-2002 09:59
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
