Go to Post This our big chance to spread the word and change the culture, let's not waste it. So in the words of one Leroy Jenkins, "Time's up, let's do this." - Frenchie461 [more]
Unread 19-01-2005, 23:52
LaughingJack's Avatar
LaughingJack LaughingJack is offline
I'm awake really...
AKA: Mike Weeks
#0753 (High Desert Droids)
LaughingJack is an unknown quantity at this point
Unhappy The Hall Effect sensor wiring?
I've spent a little over two hours searching the forums now and have had little luck. Although I've gained some new valuable information I still have a pitfall in my knowledge. I've reviewed all the threads I've found and searched the official schematic for the sensor and I am still a little confused . I was wondering if someone could post a simple diagram of the wiring (because i can't find where the four prong connector goes.) or if they could give a simple "verbal" walk through in it's connection. Is my problem with the external connection of pins 3 & 4, or am i just missing something obvious. Anyway any help is appreciated and thanks in advance.
Unread 20-01-2005, 00:04
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: The Hall Effect sensor wiring?
Cut the male end off of a PWM cable. Connect the red wire to pin 1, the white wire to pin 2, and the black wire to pins 3 and 4. Then plug the female end of the cable into the input on the RC.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 20-01-2005, 00:17
I'm awake really...
AKA: Mike Weeks
I can't thank you enough, we'll start on this right away... Thanks again
If you really want something in life you have to work for it. Now quiet, they're about to announce the lottery numbers.
KVermilion's Avatar
KVermilion KVermilion is offline
... clearly ...
#0649
KVermilion is infamous around these parts
You are forgetting the regulated power supply protection.
You saboteur!
(That last line is satire.)
Unread 20-01-2005, 00:48
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
That is only necessary if the voltage supply is very noisy. I'm pretty sure that the outputs on the RC are fairly stable and well-regulated, so you can connect the sensor directly to the RC. Or was that satire too?
Sure you can. Just be sure to stop by and say hey in the pits at Sacramento.
_
Unread 20-01-2005, 02:06
KVermilion's Avatar
... clearly ...
#0649
"The on-chip voltage regulator provides immunity to power supply variations between 4.5V and 26.5V. However, even while operating from a regulated line, some supply and output filtering is required to provide immunity to coupled and injected noise on the supply line." -- ATS660LSB Data Sheet, Pg 10
Unread 20-01-2005, 08:05
I would recommend following the circuit for regulated power supply. The use of a metal film 20 ohm resistor will also provide a little power protection should the device or the wiring short. The capacitor on that line will also kill some of the noise that might be present with all the brush tye motors running close by. The pullup load resistor may not be needed with the input circuitry of the RC.
Unread 23-01-2005, 21:46
Jerry Kingzett Jerry Kingzett is offline
Jerry Kingzett is an unknown quantity at this point
I found out what I was doing wrong when I was testing the Hall Effect gear tooth sensor thanks to these forms. I was not putting enough load on the circuit with just the oscilloscope. The data sheet showed that by placing a 500 ohm resister (RL) between the supply and the output, I was able to get a nice square wave and a steady frequency reading. I had to set up a chain ring in the drill press, because just waving a piece of metal past it gave very poor results.
Unread 23-01-2005, 21:57
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Hey,
Time for my $.02. Personally speaking, I would put the filter on it, just because it seems like a sensible idea and it seems pretty easy. Ever heard the term 'An ounce of prevention is worth a pound of cure'? Well, old cliches are often true (That's why they become cliches!). Use the instructions Al gave you, or look at the datasheet (I think they have an application circuit...). Even if you don't end up needing it, it will feel better to have some padding between it and whatever voltage fluxuations you may encounter.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 19-02-2005, 11:16
phillutz phillutz is offline
FRC #0851 (The Froggers)
phillutz is on a distinguished road
Okay here is my problem.
We have wired the sensor as discribed, but the that will only plug into 1 pwm per sensor.
Discussions state that you need to plug A phase into pwm6 and B into pwm 1
how do you wire one sensor to the 2 pwms?
Unread 21-02-2005, 10:47
The data sheet shows only one output per device. The output state is different depending on which direction the teeth are passing the sensor. You need to make that interpretation in software.
Please cite the discussion about A phase and B phase.
Unread 21-02-2005, 13:35
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
First, I assume you mean dig io, not pwm!
Second, in using Hall sensors, you actually need two placed closely together with a slight offset. You can reference the actual application note at http://www.allegromicro.com/techpub2...ion_detection/
The first sensor gives you phaseA; the second, phaseB
Ours give execllent and reproducible results. The trick is mounting them. We machines out pieces of delrin to hold them in the desired configuration. Since there are magnets in them, they want to push apart!
Jon Mittelman
Team236
Godd luck
Hall Effect Sensor. Nixterrimus Electrical 77 29-01-2005 10:48
Code violation using Hall effect sensor pickle Programming 9 19-01-2005 00:10
Chairmans Award Dinner With Dean. Josh Hambright Chairman's Award 26 20-07-2004 19:05
hall of fame nuggetsyl General Forum 15 05-05-2002 22:54
DC Motor current to an Analog Input junkyarddawg Motors 43 04-04-2002 15:53
