Re: Where to get lightweight flexible coupling?
You could always use previous year's black plastic couplings, if you want the ultimate light-weight coupling. You'd have to buy the hex shaft that fits in them, and bore/broach it to 1/2" with keyway.
First off, the above is an excellent idea. I believe we have the parts, so we will consider it.
As for what I was originally looking for I believe I have found it. Not super light but better than iron, Applied Industrial sells aluminum LoveJoy couplings. |
| Shorten The Flexible Drive Shafts? | milesdf | Motors | 2 | 08-02-2004 12:27 |
| coupling Bosch & Atwood motors | caffel | Motors | 10 | 28-05-2003 16:00 |
| SPI Wheel coupling cracking like crazy! | archiver | 2001 | 4 | 24-06-2002 00:56 |
| Motor coupling | archiver | 2001 | 19 | 23-06-2002 23:35 |
| 3.5x3.5 coupling? | ahecht | Technical Discussion | 1 | 05-01-2002 23:36 |
