Go to Post Although I have much yet to go, in my short time in FIRST I have learned there is no such thing as a waste of time, especially when a) fundraising, b) mentoring students, or c) reading directions. - Amanda Morrison [more]
Unread 13-01-2005, 23:00
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
Skyway 4WD Help
How should our team buy an axle for the Skyway wheels?
We also need another set of sprockets. (Is IFI the only place to get these?)
Where can we get these?
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 13-01-2005, 23:04
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Skyway 4WD Help
Depends what kind of wheel you're using.
If it's got bearings in it, and you're driving the wheel, not the shaft, you can use any standard shaft (The most common is 3/8" I believe)
If you're driving the shaft and not the wheel (ie: the hub is keyed) you need a keyed shaft of that size
Either kind can be found at www.mcmaster.com
P.S. I'm moving this to the technical forum.
2001-2004: Team 100
2006-Present: Team 254
Unread 13-01-2005, 23:05
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
Re: Skyway 4WD Help
Places like mcmaster or msc would be great places to get more sprockets. You can access their websites at: http://www.mcmaster.com and http://www.mscdirect.com . You can also get more shaft from them as well.
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 13-01-2005, 23:16
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
Re: Skyway 4WD Help
Be careful what advice you're giving people. Those kit sprockets have been custom bored. If you buy standard sprockets from a source other than IFI, then you will need to have them pressed onto the shaft.
See THIS.
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Unread 13-01-2005, 23:35
sirbleedsalot's Avatar
sirbleedsalot sirbleedsalot is offline
FRC #0939
Team Role: Student
sirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura about
Re: Skyway 4WD Help
You can use a bolt if you are putting it together like the kit does, at least that is what the instructions said if I read them correctly. We will be using bolts for our wheels as soon as we get them.
our web site
Unread 14-01-2005, 00:18
LBK Rules's Avatar
1467 '06 Alumni
no team (HSRO)
Re: Skyway 4WD Help
I'm so sorry, but I have found the section in the rules about the axles.
We still need help with the sprocket issue, thought.
Anthony Rinaldi
Team 1132: 2003
Unread 14-01-2005, 07:32
Nick R.'s Avatar
Nick R. Nick R. is offline
Team 1009 - Engineer
AKA: Jedi Master Talyn
None #1009 (Vikings)
Nick R. is on a distinguished road
Send a message via MSN to Nick R.
Re: Skyway 4WD Help
a 4 sprocket set (2 big ones for the skyway wheels provided[28 tooth], and two smaller ones for the gearbox output shaft[20 tooth]) ARE available at IFI robotics they come as a PACKAGE and are ~80$ ($@#$@#$@#$@#....)
btw what was it about the shafts that you found in the rules?
Nick .R. (Team 1009)
Unread 14-01-2005, 10:59
LBK Rules's Avatar
1467 '06 Alumni
no team (HSRO)
Re: Skyway 4WD Help
In the Tips and Guidlines, they said that a ceartian type of bolt makes a good axle.
Anthony Rinaldi
Team 1132: 2003
Unread 14-01-2005, 20:59
Nick R.'s Avatar
Re: Skyway 4WD Help
wich bolt is that? we cant find that part and we gotta order our...
Thanks
Unread 14-01-2005, 21:01
Cory's Avatar
AKA: Cory McBride
Re: Skyway 4WD Help
Thanks
Any 3/8" diameter shoulder bolt with a shoulder the width of the wheel well should work fine.
2001-2004: Team 100
Unread 14-01-2005, 21:02
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: Skyway 4WD Help
Thanks
Any 3/8" dia bolt will work.
I recommend: Part No. 91236A644
From www.mcmaster.com
But any equivalent part will work.
JV
Unread 19-01-2005, 23:29
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
Re: Skyway 4WD Help
The only bad thing about those sets are that you can't just get the sprockets for the wheels. Our team needs to buy 8 more to get our 6WD working and we are going to need to buy 4 sets at 80 bucks, that is not fun. We are currently trying to trade for them, otherwise, we are going to get them made. We hope to be able to get them for less than 40 bucks a piece
Elknise
Issaquah Robotics
Unread 20-01-2005, 00:02
JVN JVN is offline
@JohnVNeun
Re: Skyway 4WD Help
Originally Posted by elknise
The only bad thing about those sets are that you can't just get the sprockets for the wheels...
You may now buy individual sprockets from IFI.
http://www.ifirobotics.com/kitbot.shtml
Unread 20-01-2005, 00:34
elknise's Avatar
AKA: Erik Knise
Re: Skyway 4WD Help
Oh, Thanks. On monday our team called IFI and they said that they were not planning on offering individual sprockets anytime soon.
Thanks So much
Elknise
Issaquah Robotics
Unread 23-01-2005, 19:07
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Re: Skyway 4WD Help
the 3/8 bolt is to small for the bearings
the wheels end up being very wobbly
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Skyway Wheel Hubs Nick R. Technical Discussion 2 10-01-2005 19:53
[OCCRA]: skyway wheels REPLY ASAP oaktown1188 OCCRA 3 04-10-2004 22:23
Need Skyway Tuffwheels Joshua May Kit & Additional Hardware 4 25-01-2004 01:31
Wheel Hub Connectors for Skyway Wheels Wayne C. Kit & Additional Hardware 16 10-01-2003 07:16
skyway -> hubs/sprockets crakmunkey Technical Discussion 1 21-01-2002 14:56
