Re: Restricted to the Anderson Connectors in the Kit?
Here is the way I interpret this rule...
<R48> The ES-18-12 Battery, the Main 120 Amp Circuit Breaker, and the IFI CB/Distribution panel must be connected as shown in the diagram. The ES-18-12 Battery must use the Anderson Connector and the copper SLU-70 lugs provided in the Terminal Supply Bag. The Battery terminals and the SLU-70 lugs must be insulated with shrink tubing and/or electrical tape. You may use additional lengths of #6 red and #6 black wire to reach the panel as needed to make the above connections. The circuit breaker must be readily accessible for inspection and testing at each competition event. The #6 and the red Anderson connector provided must be used. Elsewhere in the rules, wire minimum sizes are specified, but no additional reference is made to #6. Simple answer is use what is provided. The tradeoff for lower resistance/higher weight is not significant to warrant the change. (The wire length should be too short to matter.) I would like to know what "high quality" #6 wire is? |
ID: 1167 Section: 5.3.5 Status: Answered Date Answered: 1/17/2005 Q: In reference to rule R48, can we use wire larger than #6 (such as #4) diameter between the battery and the Anderson connector and between the Anderson and the breaker panel? A: Yes Specifically that I said on the battery side also. On the other hand, the Anderson's are only designed for 6 gauge, not for 4. Tomorrow I'm going to try using some 4 gauge with some extra contacts I have. Edit: Fixed spelling, stupid 8 AM classes. Last edited by BrianBSL : 20-01-2005 at 08:04. |
Interesting answer. Go figure!
highly suprising, tell us soon wut u find so i can go out and buy the cables tonight and use it
hmmms tho just to be clear does it mean we can replace alll 6 awg wires with our own stuff? just the leads to the batteries? or can it be used at the PDB and 120 Breaker and robot battery leads? |
| need standard kit gearbox | Korbin | Kit & Additional Hardware | 0 | 15-11-2004 21:18 |
| PWM Style .100 pitch Male Connectors | BrianBSL | Electrical | 2 | 05-10-2004 19:43 |
| Q&A Discuss: How many Van door motor(s) come with the kit? | CD47-Bot | Extra Discussion | 1 | 08-01-2003 11:07 |
| RJ-45 connectors, DB25 connectors and the like: legal or no? | Andrew Wyatt | Technical Discussion | 6 | 04-01-2002 22:53 |
| 45 or 75 amp anderson power products connectors to drill motors? | Andrew Wyatt | Motors | 2 | 20-12-2001 08:00 |
