Go to Post Judging the Championship CA must be the hardest thing to do in FIRST. I'd rather try to stop an alliance of 1114, 111, and 25 from scoring 3 pointers than to judge the CA between these teams. - Andy Baker [more]
Unread 19-01-2005, 11:14
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Wiring two cameras
Originally Posted by jgannon
Conceptually, it's not that difficult. Get them both operational (with a little help from Kevin), and mount them on opposite corners of the front your robot. You know the width of your robot (likely 28"), and you can get the two angles from the values of the pan servos. You have angle-side-angle, and there's only one solution to the triangle. Now you know how far away you are. Pivot until the two base angles are congruent, and charge forward until you're the proper distance from the vision tetra. Use the same theory with the yellow triangle to the goal. It's very doable, and I'd love to pull it off. I can't think of a more incredible nerd feat attainable at this age than to meet Dave Lavery's personal challenge.
Actually, conceptually it is not that simple. Remember, the challenge is to come up with a real stereo correlation solution, not a simple geometric one. The biggest problem is that there are multiple vision tetras out on the field. You have to compute the true correlation between the camera images to determine if both cameras are looking at the same target. Only then can you back-solve the geometry.
If I am going to give away six dozens tasty treats without allowing any for myself, I have to make sure that the challenge is really worth it! C'mon, are you all going to leave Kevin as the only contender?
-dave
Unread 19-01-2005, 13:39
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Ummmmmmmmmmm....
I like Donuts
if i cant get some more funds maybe i can convince our programmer to do it
....He likes donuts too
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 19-01-2005, 15:41
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
-dave
I think it's doable, with enough if statements. But, once again, my inspiration is not limited by lack of programming prowess, or lack of time, but rather lack of resources. Pity we don't have a mob boss *coughbeattycough* doing our fundraising, or I'd be all over this. Enjoy the donuts, Kevin.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 19-01-2005, 15:49
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Dave,
Well, I've hit a snag. After an all-night Mountain Dew and pizza-fueled programming session, I've got 19 robot controllers setup as a pipelined stereo vision processor running the 27,000 lines of MER stereo vision code that I ported to PIC C18. I have an additional 53 robot controllers running a pipelined version of the MER "GESTALT" local path planner. Everything seems to run pretty well, but my EX18-12 battery completely discharges in only 5 seconds. I asked the crack FIRST engineering staff to make an exception to rule <R46> and allow me to add the additional three batteries I need, but they wouldn't budge. I then asked if I could use a flux capacitor for power, but that didn't go over too well, either (they did say I could use it for decorative purposes, though). Anyway, can I get some partial credit for the effort? I'd be pretty happy with just two dozen.
-Kevin
Kevin Watson
http://kevin.org
Unread 19-01-2005, 15:53
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Talking Re: Wiring two cameras
Originally Posted by Kevin Watson
Dave,
-Kevin
If you use the flux capacitor your robot will still have to drive 88mph.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 20-01-2005, 02:39
Dave, is IFI giving you a kickback? For $40 out of your own pocket you get multiple teams buying $200 cameras from IFI. That's not to mention the 60+ robot controllers that Kevin bought
Unread 20-01-2005, 03:18
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
I thought the flux capacitor let you travel through time, it was the plutonium that gave that 1.21 giga-watts of power (then came Mr. Fusion, which kinda makes me wonder, where did all that extra plutonium go anyways? If it never left the car, then when the train killed the delorean, wouldn't there be a big problem?).</offtopic>
Kevin, what about a wall outlet (with an adapter, of course)? 500ft extention cord? =D
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 20-01-2005, 07:49
Dave,
-Kevin
Kevin,
The flux capacitor should have been allowed under the flowchart as long as it met the single component maximum cost. I did check with Digikey and they no longer carry the line. Apparently there is a world wide shortage of material now that we are approaching a sunspot minimum. The plutonium is another problem as it does not pass the hazardous material test and the Mr. Fusion would not either for the smell of the garbage you put in. (Inspection list "Do you have anything that smells bad or can damage the carpet?") However, you could charge it up by having all the competition attendees hold hands and shuffle across the carpet. (I am not volunteering for the last person in the line, I am going to be busy that day!) See, only simple solutions, I don't drink Dew so my head is clear.
Unread 20-01-2005, 08:24
Electrical Engineer
Rookie Year: 1995
Originally Posted by NoodleKnight
I thought the flux capacitor let you travel through time, it was the plutonium that gave that 1.21 giga-watts of power...
I believe the unit of measure was jiga-watts vice giga-watts...
Mike Betts
As easy as 355/113...
Unread 20-01-2005, 09:00
patTeam241 patTeam241 is offline
College Student
AKA: Pat Cleary
patTeam241 will become famous soon enoughpatTeam241 will become famous soon enough
Send a message via AIM to patTeam241
Instead of coming up with a complex stereocamera system, could you come up with a somewhat mechanical one. If memory serves me correct, you can set up the CMUcams to drive servos to center a color on the screen. If you then read the rotation with a potentiometer, couldn't you just triangulate the distance?
Unread 20-01-2005, 10:18
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
You don't even need potentiometers... you can just read the values of the pan servos. If you scroll up a ways, I talked about how you could triangulate it, and then Dave explained why it's not quite that simple.
_
Unread 20-01-2005, 11:47
dlavery's Avatar
Curmudgeon
Thus we come to the nut of the problem. That would work if you could guarantee that only one object of the target color could ever be in the field of view of the cameras. But since there may be up to four vision tetras visible from any location, plus the potential for background items of the same color to be detected, you will need to deteremine the true correlation of the objects in the image to determine if the cameras are looking at the same target object.
-dave
Unread 23-01-2005, 17:57
Karma Karma is offline
AKA: Daniel Takamori
FRC #0955 (Raiderbot)
Team Role: Electrical
Karma is an unknown quantity at this point
Send a message via AIM to Karma Send a message via MSN to Karma
So in the Team Update 3, it said we could use another vision camera on our robot. Does that include any other types of cameras, such as USB? Some teams will be using Co-Processors, and thus have the capabilities to use more than two cameras, is this use even allowed? Thanks for all your help, and 955 will be the ones who win the donuts.
Unread 23-01-2005, 18:44
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
To the first team that successfully enables two CMUcamIIs on their robot and uses the PIC microprocessor in the IFI robot controller to compute the stereo correlation from the two camera images to determine range to the designated target, within the time limits of the autonomous period, I will personally award six dozen Krispy Kreme donuts.
Yes, it is physically and electrically possible to connect multiple CMUcams to the RC. But once you do, what are you going to do with the data?
-dave
(OK, now that I have said this, just watch someone like Kevin Watson have a working solution by this Friday... )
And yet after... 3 days of trying I still havent gotten one camera to control anything but the servo on the camera board . Back to re-reading for a 20th time.
-dave
I think I know how to get two involved and finding the correct tetra between the cameras but again I need to get it working with one first.
-Mike
Unread 24-01-2005, 23:51
kham's Avatar
kham kham is offline
K. Ham
FRC #2819
kham is an unknown quantity at this point
Two cameras? Jeez, we're still trying to figure out how to implement one camera...
Electronics Board Construction/Design zdeswarte Electrical 10 28-01-2005 00:09
Neat & Organised Electric Wiring thoughtful Electrical 30 13-12-2004 22:46
Digital Cameras Ian W. Chit-Chat 15 08-09-2004 17:48
Lost cameras at Georgia Dome Aidan F. Browne Championship Event 7 19-04-2004 11:53
Help wiring Line sensors magical hands Electrical 1 18-02-2004 10:17
