Go to Post work hard, think hard, and have fun doing it. - ebarker [more]
Unread 20-01-2005, 05:30
Dave Garnett Dave Garnett is offline
Dave Garnett is an unknown quantity at this point
Gas Springs Allowed ?
I'm not sure what you call these things in the US, and I'm not sure whether they are considered pneumatic components because they do not connect to any pneumatic system. The Question is 'Are gas springs allowed (COTS, unmodified) ?' (The sort of thing used to hold up auto tailgates).
Unread 20-01-2005, 07:40
Swan217's Avatar
Swan217 Swan217 is offline
RoboShow Producer
AKA: DJ Royal Fusion
no team (RoboShow)
Swan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond repute
Send a message via AIM to Swan217
Re: Gas Springs Allowed ?
Yes, gas springs are allowed. Last year, we (217) designed our arm with a gas spring, but had to remove it because of weight. This year, we plan to use gas springs again for our lifting mechanism (whatever it may be ).
Orlando Regional Planning Committee & Cohost of The RoboShow & RoboVision
Follow The RoboShow on Twitter @RoboShowLive & check out our website, www.theroboshow.net
Follow RoboVision on Twitter @RoboVisionOD & check out our website, www.robovisionod.com
"As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything."
— President Barack Obama
Unread 20-01-2005, 09:38
<R91> has your answer.
Unread 20-01-2005, 10:31
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Can someone explain what advantages a gas spring has over a regular spring or elastic part?
Team 1257
Unread 20-01-2005, 10:36
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
First thing that comes to mind is that the is no material that has to flex that could wear out or whatever. They probably weigh more than a regular spring..... Actually I dunno. If there were raised areas in the playing field this year I wanted to bust up some of these rolley chairs in the classrooms where we work, and jack the little gas shock type deals to use as shocks for our bot. As it is I guess we get to focus more on a grabber thingy. Dangit Im off topic again.
Unread 20-01-2005, 10:39
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
For one thing, gas springs are safer than coil springs since a smooth piston is usually the only exposed moving part. 'No place to get yourself pinched.
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Unread 20-01-2005, 13:37
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
And a gas spring is less likely to go flying if it gets dislodged.
See you in DC!
[OCCRA]: motor brush springs greencactus3 OCCRA Q&A 1 28-09-2004 20:56
How long can car idle on a tank of gas? sanddrag Chit-Chat 11 13-09-2004 12:46
Gas powered engine horsepower equivalent to electrical motor horsepower? Elgin Clock Motors 30 22-08-2004 20:44
Constant Force Springs - Data Sheets? Ben Piecuch Kit & Additional Hardware 1 06-05-2004 19:00
Boldly going where no team has gone before... archiver 2000 6 23-06-2002 23:42
