Go to Post Yes, an expanded FIRST will look far different than it does today. - GaryVoshol [more]
Unread 20-01-2005, 12:40
team1307 team1307 is offline
team1307 is an unknown quantity at this point
Send a message via AIM to team1307
Re: USB Joystick to DB15
This might be a stupid question but wouldnt it work if we found some way to convert db9 to db15? I know that 6 pins would have to be unused.. Is it a data collision problem?
Unread 20-01-2005, 13:16
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
There is no data to collide. The OI just uses the raw measurement from the joystick pots so it needs a 0-100K "signal". Most of the newer joysticks/pads uses an interpreter between these raw signals and the computer to convert them into RS232 or USB protocol.
Other than taking your joystick apart, disconnecting the joystick potsfrom the circuit board, meauring them to make sure they are 0-100K linear pots, and then rewiring them, you won't be able to use them.
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 20-01-2005, 13:18
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Most joysticks these days use some optical sensing technology instead of pots. Note if it has trim's or not, chances are if it doenst have trim's, it doenst use pots, it just checks for change, it could care less about absolute posistion.
Unread 21-01-2005, 09:52
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
One option to keep in mind, is to scrap the USB connector, and rewire the whole thing. Its quiet an undertaking but i have done it. We rewired a really nice flight sim joystick and throttle set to control a crab drive robot once. Just memorize those OI datasheets and get some db15 connectors and start splicing wires!
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 21-01-2005, 11:58
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
The problem is that the OI measures voltage from 0 to 5 volts, and turns it into a number from 0-255. You get a variable voltage using a potentiometer, which is what you'll find in the kit-provided joysticks. The problem with modern joysticks is that they give a digital output, sending pulses on a wire. The OI cannot process this sort of signal. Even if you converted the connector to DB9, you'd still be getting the same sort of signal. Your joystick probably uses analog values to generate the digital signals, so if you're feeling courageous, you could open up the joystick, bypass much of the internal circuitry, and wire the potentiometers directly to the proper pins on a DB15 connector. If your joystick uses some fancier sort of sensor (optical, perhaps), it might be a little different. The point is, it's likely that you can get your joystick to work with the OI, but the rewiring you'd have to do would be internal.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
