Go to Post My robot is my significant other. It makes me happy, sometimes it makes me sad, i wish it would lose some weight but it is always there for me. - rachelholladay [more]
Unread 20-01-2005, 07:00
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Post Robot Part Weight List
So, since this is probably the time of the season where teams are really starting to realize their designs and doing some weight calculations to see how close to the limit you are, or if x motor can power y device, or if your robot is going to tip over, I thought it would be nice to have one common location for weights for different devices. I'll start with what I have so far, and if people add to the list below my post, I will update this first post with the new parts. Also, I will show parts as verified if somebody confirms a weight. At least it will give you a starting point for weight watching (tm?).
Can anybody show me how to do a table, if possible?
BTW...NBD is Nothing But DeWalts
Also, at the end, I'm listing items I am going to try and find weights for by searching or weighing myself when I get to the lab tomorrow. But, if you have any information about anything, I will add it to the list. Thanks!
Format:
Part name, Numeric Value, Units, Verified, Note
Pillow Block Bearing, 12.9, Oz., Not Verified, Kit part FAFNIR
1" Sq. Aluminum Tube 0.062 Wall, 0.274, lbs/ft, Not Verified, Alro Catalog
1x2" Aluminum Tube 0.125 Wall, 0.808, lbs/ft, Not Verified, Alro Catalog
3/4" Aluminum Round 0.125 Wall, 0.391, lbs/ft, Not Verified
1/4" Aluminum Plate 6061-T651, 3.63, lbs/sq ft, Not Verified, Alro Catalog
1/8" Aluminum Plate 6061-T6, 1.764, lbs/sq ft, Not Verified, Alro Catalog
1/16" Aluminum Plate 6061-T6, 0.889, lbs/sq ft, Not Verified, Alro Catalog
Battery, ~12, lbs, Not Verified, Weight varies slightly battery to battery
Battery Connector
Compressor
CIM Motor
CIM Motor NBD
Fisher Price Motor
F-P Motor NBD
F-P Motor w/ Gearbox
Globe Motor
Globe Motor NBD
Mabuchi Motor
Window Motor
Van Door Motor
Clippard Tank
RC
Spike
Victor
Power Dist. Block
Solenoid Valve
6 AWG Wire
10 AWG Wire
LED's
#35 Chain
#25 Chain
5/8" Steel Shaft
3/8" Steel Shaft
3/8" Aluminum Shaft
#35 Sprockets
#25 Sprockets
Wheels and Tires
5/8" Bearings
3/8" Bearings
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 20-01-2005, 07:44
Swan217's Avatar
Swan217 Swan217 is offline
RoboShow Producer
AKA: DJ Royal Fusion
no team (RoboShow)
Swan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond repute
Send a message via AIM to Swan217
Re: Robot Part Weight List
Team 234, Cyberblue has an excellent spreadsheet for calculating weight. You can download it here:
http://www.cyberblue234.com/cyberblu...htdatabase.xls
Orlando Regional Planning Committee & Cohost of The RoboShow & RoboVision
Follow The RoboShow on Twitter @RoboShowLive & check out our website, www.theroboshow.net
Follow RoboVision on Twitter @RoboVisionOD & check out our website, www.robovisionod.com
"As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything."
— President Barack Obama
Unread 20-01-2005, 09:25
Don Wright's Avatar
FRC #0469
I can't seem to be able to open that Excel file... It just locks up. I did download it to my machine before opening too...
Product Manager
Unread 20-01-2005, 12:55
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Here's what I can contribute for now. These were weighed on our electronic scale, accuracy is probably +/- .1 lb.
AndyMark Shifter w 2 CIM 9.9 lbs
Van Door Motor 2.7 lbs
ND Window Motor 1.9 lbs
Jideco Window Motor 1.5 lbs
Globe Motor w gearbox 1.1 lbs
Air Compressor 4.6 lbs
Battery 12.7 lbs
Pete Kieselbach
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
What scales to weight robot? chocolateluvrlr General Forum 41 08-04-2005 21:43
Robot size and weight Covey41 Rules/Strategy 8 10-01-2005 10:32
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
