Go to Post Be not afraid, go forth and multiply. - Pat Major [more]
Unread 18-01-2005, 21:41
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
CMUCam Upside-down?
We set up the CMUCam in the orientation shown in the documentation, and noticed that the images in the "Camera View" window were right-side up. However, in the "Color" window, the images returned are all upside-down. Yes, you can flip the image in the "Camera View", but shouldn't the default orientation be the same for both?
Zan Hecht
Unread 18-01-2005, 22:09
roboticsguy1988's Avatar
roboticsguy1988 roboticsguy1988 is offline
Larry Johnston
AKA: Larry Boy
FRC #1501 (Team THRUST)
Team Role: Electrical
roboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud of
Send a message via ICQ to roboticsguy1988 Send a message via AIM to roboticsguy1988 Send a message via MSN to roboticsguy1988 Send a message via Yahoo to roboticsguy1988
Re: CMUCam Upside-down?
We have had the exact same problem. If you notice though the robot still tracks like it is suppose to. I mean if you look at the tracking window and move the yellow triangle to the left it moves right on your screen, and if you move the triangle up it moves down on your screen. However i think the robot code reverses this in someway. because the robot does move toward the color like it is suppose to.
Larry Johnston, Team THRUST, Team #1501, Team THRUST webpage
2005 IRI - Imagery and Design Award
2005 - 2006 BMR - Professional Grade Award
2006 BMR - Delphi Driving Tomorrow's Technology Award
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~ RogerR
~Da team that uses all tha rivets, Team #1501~
The FIRST Software Repository ~ Chief Admin
openFIRST ~ Project Supporter (Former editor)
DMOZ.org - FIRST - US Teams Section ~ Chief Editor
Unread 20-01-2005, 14:53
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Must be a problem with the GUI (which is poorly coded anyway).
As far as how to fix it, no clue. Make sure you have an up-to-date version of the JRE and such.
Unread 20-01-2005, 14:56
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team 188's experience with the CMUCam2 Java GUI is the same as roboticsguy1988.
Even though the "Color" image is inverted from the "Camera View" image, the tracking works fine, and our robot also moves toward the color like it is supposed to.
-SlimBoJones...
Unread 28-01-2005, 23:44
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Go to your config tab and select Invert Color Tracking (or something similar to that)
http://www.mikesorrenti.com/
Unread 28-01-2005, 23:48
Larry Johnston
AKA: Larry Boy
You know it could just be the program itself messing everything up, and not the camera. If not though inverting the color tracking will not help. because if the camera is truly like that then it will be like that when running during a competition.
Unread 29-01-2005, 00:22
russell's Avatar
russell russell is offline
#1430 (WRONG)
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Ours is like that too, but it works just fine when we hook it up to the robot. I dont really know or care why just so long as it works, but I add my vote to the "Our picture is upside down in the color tracking view and by the way the GUI sucks" column.
Unread 21-02-2005, 12:40
Fixen Fixen is offline
The Sleepless Coder
FRC #0423 (Mechanical Mayhem)
Fixen is on a distinguished road
Umm...our camera is upside down, and we can't calibrate it because the triangles kept going out of the grid.
Any help?
Unread 27-02-2005, 10:25
kokodabear's Avatar
kokodabear kokodabear is offline
HELP!
AKA: Brady
#0686 (Bovine Intervention)
kokodabear is an unknown quantity at this point
Send a message via AIM to kokodabear
Any help?
I don't completely understand what your problem is. (What do you mean by grid?) Try explaining what's wrong in a bit more detail and I may be able to help you.
CMUcam setup Ryan Collings Programming 26 13-01-2006 01:00
Strange CMUCam Image Sidney San Martín Programming 22 27-01-2005 15:00
CMUCam not working. Matt Krass Programming 4 18-01-2005 14:08
CMUCam for drivers patTeam241 Technical Discussion 22 16-01-2005 01:21
EDU-RC, USART2 (TTL), CMUCAM ChrisHomer44 Programming 2 30-04-2004 21:38
