Go to Post Scouting wins championships folks...not draft orders. - Andy Grady [more]
Unread 20-01-2005, 14:58
KoRnPoP's Avatar
KoRnPoP KoRnPoP is offline
Webmaster/Driver/Fabricator
AKA: Michael
FRC #1598 (Team Talon)
Team Role: Webmaster
KoRnPoP will become famous soon enough
Send a message via MSN to KoRnPoP Send a message via Yahoo to KoRnPoP
How to get the robot to stop...
Does anyone know how to get the robot to stop in autonomous mode with out using script?
Unread 20-01-2005, 15:04
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: How to get the robot to stop...
I'm not sure if you're trying to stop the robot using software (as in, if we run into something stop) or if you mean that you want to be able to kill the robot in mid-stride because you can tell it's just about to rip its arm off.
For the first thing, you just have to set the variables pwmXX and pwmXX to 127 in your code, where the two XX is where your motors are hooked up.
For the other option, which only works when you're on your practice field, you build a dongle, which is basically just a few stiches which connect/disconnect a few pins on the competition port on the operator interface. I'm not sure right now exactly where those are, but there is lots about them here. Do a search.
Unread 20-01-2005, 15:57
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
while(1);
Works every time!
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 20-01-2005, 16:27
RIgnazio RIgnazio is offline
RIgnazio will become famous soon enough
Love it!
Ok, anyways, back to the making the robot stop. In autonomous mode, what I find that works best is at the end of the loop, use
else
pwmXX = 127;
pwmXX = 127;
where XX is your PWM number. Now, you can create a little snippet like this:
#define pwm_neutral 127
What that will do is let you use pwm_neutral and it will equal 127. If you don't like working with numbers, that is. I also do a
#define pwm_max 254
#define pwm_min 0
for max and min speeds.
Unread 20-01-2005, 17:33
buss buss is offline
AKA: Steven
FRC #0180 (S.P.A.M. Robotics)
buss has a spectacular aura aboutbuss has a spectacular aura about
Send a message via AIM to buss
Last year my team (S.P.A.M. #180) ran into a serious problem during autonomous. If we ran into something and the robot didn't fix itself, we would continue driving forward and start to burn holes into the carpet. If you have some sort of motion sensor (be it an accelerometer or something equivalent) have a counter going that adds 1 every loop. Each time the sensor returns data, have it zero the counter. So if the sensor doesn't return anything (I.E. you're not moving) then the counter will count to whatever you have set as the max. When it reaches the max, set the motors to neutral (127). This bit of code kept us from being disqualified for field damage for at least five matches during one regional.
That may not be exactly what you're asking for, but its good none-the-less.
Steven Buss
"Far and away the best prize that life offers is the chance to work hard at work worth doing."
-- Teddy Roosevelt
pic: 2003 TechnoKat Ball Drive : Patent Pending CD47-Bot Robot Showcase 78 30-03-2003 16:27
pic: Ball Drive Close Up CD47-Bot Robot Showcase 17 04-03-2003 15:23
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Fork Lift Robot tinyfarnsworth General Forum 64 16-04-2002 12:09
Index of team's post about their robot... Ken Leung Robot Showcase 1 20-03-2002 17:10
