Go to Post Scout team, assemble! (preliminarily) - PayneTrain [more]
Unread 17-01-2005, 20:17
kshot kshot is offline
#0968 (RAWC)
kshot is an unknown quantity at this point
Send a message via AIM to kshot
Rookie programmer in need of help.
Hello all,
This is pretty much my first year of doing programming in C for purposes other than using it in robots. I was wondering on how to put a line of code in to add a button that would act as a click switch and tell the RC that a button was hit, and then it would proceed onto the next line of programming.
Thanks.
Unread 17-01-2005, 20:36
Electrical Engineer
Rookie Year: 1995
Re: Rookie programmer in need of help.
Originally Posted by kshot
Hello all,
Thanks.
Kshot,
Do you want the button to be at the operator interface (such as a momentary switch that the driver pushes) or on the robot (such as a micro switch indicating an arm is at the end of its travel)?
Mike Betts
As easy as 355/113...
Unread 17-01-2005, 20:44
#0968 (RAWC)
Well, I wanted the button to be placed in front of the robot, then as the driver pushes the robot forward, if the button is pressed (vision tetra is being pushed against the robot), then the program would then execute it's next stage.
Unread 17-01-2005, 20:55
Electrical Engineer
Rookie Year: 1995
See page 11 of 2004-programming-reference-guide-12-apr-2004.pdf (at the bottom of Perform Operations Example)for an example of how to reference a digital input. In this case, they use rc_dig_in01 to decide what to do (will the roller stop or go?).
You would need to connect your switch to digital input #1 on the robot controller for this to work.
Does this help?
Mike Betts
Unread 17-01-2005, 21:27
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
I think you are saying that after the switch is hit, then a new section of code is enabled. Yes? And I think you want the code to remember that the switch had been hit, even after the switch is no longer pressed?
(experienced programmers, please check for errors. I did this off the top of my head!)
In the file user_routines.c...
In the function User_Initialization(), make sure:
// tell the controller that we want to use io pin 15 as an input:
digital_io_15 = INPUT;  // or whichever input you want to use
also, somewhere in user_routines.c, near the top:
#define  MY_SWITCH rc_dig_in15  // makes the other code easier to read
In the function Default_Routine(void), add your code like this:
near the top
static unsigned char switchWasHit = 0;
later:
// when the switch is hit, it closes, and pulls the input low i.e. 0
if ( MY_SWITCH == 0 )
   switchWasHit = 1;   // remember forever
if ( switchWasHit )
  /* this is never executed before the switch is hit, and is
      always executed after the switch is hit
Remember that Default_Routine(void) is executed over and over again, about 39 times a second.
Does that help?
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 18-01-2005, 10:25
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
I think he may want to go even further and basically have a debug switch. When he hits it, then the next line of code is executed, then the robot waits again.
I'm not sure if this is possible on the RC. On a computer, debuggers typically work by hooking into a software interrupt (don't remember which one right now) and stopping execution when it is activated. I'm not sure if a similar thing exists on the RC, but if it does and you get that working, you'd be my hero.
Unread 19-01-2005, 01:59
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
if what Ryan M. says about kshot's objectives is true, the simplest way would probably be with a finite state machine and a variable to determine if the robot is in a 'wait' state.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 20-01-2005, 15:05
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
If you're refering to every line of C, than yes it would be, because data has to be returned to the master processor in a timely manner.
However, if you're refering to scripting (or any other high-level, multi-cycle sections), than this is entirely possible.
A ? about NASA grants computhief263 General Forum 18 29-03-2004 13:35
Rookie Regionals rachakate Regional Competitions 5 24-03-2004 00:01
TEAM 121 and a rookie team on CBS SAT MORNING! Joe Menassa General Forum 7 21-03-2002 00:47
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
