Re: Starting Facing Backwards?
i don't believe there would be anything against it
doesn't seem like something that they would have a problem with, as long as its still in the "blocks"
No matter how you set it up, as long as its in the blocks and satisfying all other conditions previously stated by first, you are fine. 67, a doorwedge shaped bot, started against the wall last year, wheels on the wall, and plopped themselves down in autonomous, so basically any setup should be fine.
Forward isn't really definable anyway. You can design your robot to have no specific directions. Definitely seems like any position is allowed.
There would be nothing wrong with stating backwards. It is actually a very good idea if you start in the "B" position and want to cap a tetra right away.
I was reading in the book, and as others said, all you have to do is just fit in your 'area'. I've heard of other robots in the past that have started in other positions. One robot that was really cool that I've been trying to get more information on was the robot that had started on its side and then fell down onto the field. I think that was 2001 or 2002...I don't remember. But good luck on your robot.
#7
Like said before you can start sideways, upsidedown, rightside up, left side up, etc.....
As long as the robot fits in the inspection box and starts that way every match it will be ok. You must also follow the other rules such as the one that states you must be touching the driver side wall before the match starts. One last thing In 2003 our robot did not have a front or back... We had a switch on our controls that flip-flopped the joystick controls. One side of our robot was designed to stack the boxs and the other side was designed to plow boxes. |
| Starting a Regional | unapiedra | Starting New Teams | 0 | 09-01-2005 21:37 |
| Who do I go to first about starting a new team? | aaronbr28040 | Starting New Teams | 16 | 23-11-2004 17:09 |
| HELP!! i need help starting a new team!! | shyra1353 | Starting New Teams | 18 | 07-10-2003 17:55 |
| advice on starting a team.. | archiver | 2001 | 1 | 24-06-2002 03:20 |
