Go to Post FIRST robotics: Not just for nerds. - Koko Ed [more]
Unread 17-01-2005, 21:52
Atman's Avatar
Atman Atman is offline
"Bring the HAMMER" Go 364
AKA: Team Godfather
#0364 (Team Fusion)
Team Role: Driver
Atman has a spectacular aura aboutAtman has a spectacular aura about
Send a message via AIM to Atman
What kind of material will you be using for your arm/forklift?
Alright, you have your designs drawn and a some type of base built. Your ready to start constructing that beefy arm you've been dreaming up all week. My question to you is this what kind of material will you be using to get the strength you need with conserving as much weight as possible.
2004 Lone Star Champ
2004 Lone Star J&J Sportsmanship
East Coast Drivers Union
Unread 17-01-2005, 21:57
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: What kind of material will you be using for your arm/forklift?
We are planning on a 4x4 1/8" thickness aluminum rectangular tube with serious trussing in it (40% of mass removed). I have seen several arms like this, and they looked plenty beefy.
Team 1257
Unread 17-01-2005, 22:01
Atman's Avatar
AKA: Team Godfather
#0364 (Team Fusion)
Team Role: Driver
Yea are main concern is weight but we have found a way out of that. We have our drive train built and with base transmission wheels compressor tanks and other basic stuff we are looking at or around 60lbs. So aluminum is out of the picture for us but it worked great last year.
Unread 17-01-2005, 22:15
Brandon Holley's Avatar
Our team is looking towards the plastics as our friend for this task. We have some modified plastic material that could prove to be plenty strong.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 17-01-2005, 22:46
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Why is aluminum out of the picture for you?
Almost all arms I have ever seen have been made from aluminum. Whether is be angle aluminum, extruded aluminum (80-20), aluminum box tubing, or aluminum round stock.
From what I read I think you mean using a heavier stronger material such as steel. There is no reason at all to make part of the arm (or the whole) steel. It needs to move (apparently) and the lighter it is, the easier it is to power. I also think that the forces on your arm are not going to be any where near enough to require it to be made from steel. Proper use of aluminum does wonders.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 17-01-2005, 23:25
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Right now our arm is being designed with aluminum. But the extrusions that its made of are very common. It could be switched out for other materials as long as they come in the general shapes(square, C, L, etc.).
Team Website
Unread 18-01-2005, 02:23
SteveO SteveO is offline
SteveO will become famous soon enoughSteveO will become famous soon enough
Most likely the team will use square aluminum tubing. It proved plenty beefy last year.
Unread 18-01-2005, 06:31
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
As of now we are looking at 80/20 extruded aluminum.
Unread 19-01-2005, 19:05
Jeffel Jeffel is offline
AKA: Jeff Ellis
#0269 (Cooney Tech Robotics)
Jeffel can only hope to improve
Send a message via Yahoo to Jeffel
like last year our frame is made out of Chromali. Light as aluminum but much stronger... although very expensive.. i dont even know how we paid for all of it but thats what were using this year for the frame and the prototype made now also has the arm made out of that.... we need as light as possible because of all the weight from our pneumatics. we have 3 or 4 pistons to run through out the match so its gonna be heavy
last year we used triangular aluminum for our telescopic arm... idk if any of you noticed our robot last year? midwest champs? #269
Jeff
Unread 20-01-2005, 15:11
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
We are planning to use 2" ID aluminum tube. Seems very stiff, and is also very light. McMaster Carr sells it.
Unread 20-01-2005, 21:20
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Antimatter.. It will help us in the never ending quest to build the bot under the weight limit.
Unread 20-01-2005, 21:23
Umm Errr...
Either Al square or thinwall steel tube
1139 Alumni
Unread 21-01-2005, 00:12
Atman's Avatar
AKA: Team Godfather
#0364 (Team Fusion)
Team Role: Driver
Talking Re: What kind of material will you be using for your arm/forklift?
Tell me more about this material. One of the kids on our team has a dad that manages a composites manufacterur. So we have been looking at some different things including carbon fiber and some other composites. Please weight is always a problem for us and we cannot afford to use alluminum this year. This is why i created this thread was to see some different composites and alloys.
Unread 21-01-2005, 13:35
I think he might have been referring to "chrome-moly," which is a steel alloy of iron, molybdenum, chromium, and sometimes manganese. It's a common material in high-end bicycle frames, especially in Italian or custom-made bikes. It is heavier than aluminum, per unit volume, but has better ductility, and can be brazed or welded. The lightest bicycle frames now are composites, but right behind those are aluminum and chrome-moly. It's been a few years, but a favorite chrome-moly tubing around 1970 was Reynolds 531.
Most carbon fiber composite parts are mind-bogglingly expensive. I would be interested in hearing more about how you are thinking of fabricating composite components.
Unread 21-01-2005, 13:39
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
None #1208 (Metool Brigade)
EOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant future
Aluminum extrusion with 24" drawer slides for a telescoping arm. Still being built. We'll see.
**FIRST EMAIL**/Advance Material List for the 2005 Competition Now Available! Travis Hoffman General Forum 85 08-01-2005 00:16
Cheezy Poofs' Wheel Material evolution Technical Discussion 6 18-04-2004 23:11
What kind of Palm do you have??? Pin Man Chit-Chat 19 06-04-2003 19:40
Illegal material PDonovan Rules/Strategy 13 16-05-2002 16:53
Best material for wheels. Dr.Bot Technical Discussion 0 21-01-2002 23:32
