Go to Post It's your duty in FRC to your teammates and alliance partners to put the most competitive robot possible on the field. - Chris is me [more]
Unread 20-01-2005, 17:46
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
Linear amplification through transisters?
I am a mechanical guy and i have a little knowledge of electronics. So i am going to post a question that i am sure someone else can answer for me. Is there any way to amplfy a voltage by means other than another power source? I was thinking transisters, is that possible and how would i do that?
Thank you for your help
"I'm sorry, after all he is just a wookie!"
Unread 20-01-2005, 18:23
Umm Errr...
Re: Linear amplification through transisters?
What exactly is it that you are trying to do? It sounds like you are trying to amplify a voltage to a higher voltage than is available? I could be of alot more help if you could give more specifics on what it is you are trying to do. What is the intended purpose of this circuit?
1139 Alumni
Unread 20-01-2005, 18:25
dddriveman's Avatar
AKA: Driveman
Actually i need to amplify the amperage not the voltage
Unread 20-01-2005, 18:59
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Amplification can be done many ways. Transistor and op amps are two of the more popular ways But to help you on this problem we need some information on the source and destination impedance and signal levels.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 20-01-2005, 19:17
dddriveman's Avatar
AKA: Driveman
we are using it to power a small motor connected to a 5v output. I am not sure what the impedance is.
Unread 20-01-2005, 19:27
Umm Errr...
your still holding out on us here. We need more info. What will the input to this circuit be? What power is available? How big is this motor? Elaborate a bit more on this 5v output. We would be glad to help but we need to know what it is we are helping with.
1139 Alumni
Unread 20-01-2005, 23:41
Electrical Engineer
Rookie Year: 1995
...Is there any way to amplfy a voltage by means other than another power source?...
Without a energy storage device or external power supply: You can amplify the voltage at the expense of the current and you can amplify the current at the expense of the voltage.
There are no free rides in life (and no perpetual motion machines!)...
Mike Betts
As easy as 355/113...
Unread 21-01-2005, 13:47
D,
I am going to go out on a limb here and guess that you have a 5 volt motor you are trying to turn on with a logic digital output switching between 5 volts and ground. You are running into a problem that the motor won't start by itself even though you are sure the digital output is going to 5 volts when you want it to. So here is one method to get this working, it will allow turning in only one direction though. You need a NPN transistor capable of the current needed by the motor to run. I like 2N3055 but they are big and clunky (TO-3 case). Connect one terminal of the motor to the power supply 5 volts. Connect the other side to the collector of the transistor. Connect the emitter of the transistor to power supply ground, and connect the base to the digital output.(It may be wise to start with a 1000 ohm resistor in series with the base lead.) When the digital output goes high, the transistor collector and emitter will act as a short, grounding the lead of the motor attached to the collector. The motor is now effectively connected to 5 volts and ground. If the motor is turning the wrong direction, simply reverse the leads of the motor. Does this help?
Unread 23-01-2005, 22:14
dddriveman's Avatar
AKA: Driveman
Originally Posted by Al Skierkiewicz
D,
That answers it thanks
Unread 24-01-2005, 09:55
ttedrow's Avatar
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
Hopefully you know that this motor you are asking about cannot be used on a FIRST competition robot.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
Yes, Chute Door!!!
