Go to Post Code doesn't break. It reacts exactly the same time every time. When something new happens that never happened before, it's because the mechanicals, electricals or drivers gave the code some new stimulus that wasn't tested before. - GaryVoshol [more]
Unread 21-01-2005, 04:41
or yaniv or yaniv is offline
or yaniv is an unknown quantity at this point
camera code
We download the User code with the camera support, and we don't understand what we need to change in this code, for the robot will drive with color direction form the camera.
We need only to change the parameters of the color?
Or
Unread 21-01-2005, 07:32
Electrical Engineer
Rookie Year: 1995
Re: camera code
You have to do what the rest of us are doing.
1. Go through the code line by line and understand what it does.
2. Make a list of requirements of what your robot needs to do.
3. Alter the code to fit your robot design.
This is not plug and play. You are going to have to do a little work.
Mike Betts
As easy as 355/113...
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
