Go to Post PS: Please use the default font for postings, it is so much easier to read. - DonRotolo [more]
Unread 21-01-2005, 09:42
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Re: Victor 884 problem
Although i cant for the life of me at the moment remeber why they switched to 884's instead of 883s (although i do remeber sorting all of our victors out into piles for ones we could use and ones we couldn't) I know that the 883's had a 60A output while the 884's have a 40A output.
I'd say that people are correct in making sure that no metal shavings get inside the victors, there is no easier way to release the magic smoke inside of them then getting metal shavings inside there.
I would recommend contacting IFI about this, they might be able to help you determine if infact it was faulty or if it was just user error that caused the problem.
A word of advice though, make sure if your doing any sort of work with metal around your electronics that you cover them with a cloth or at the least a piece of paper. If at all possible remove the piece of metal or the electronics in the area when working on them. This goes for motors, victors, spikes, anything that uses electrical current, as metal shavings are a deadly force on these.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Physics Problem Venkatesh Math and Science 13 30-11-2004 20:30
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
