Go to Post When a team is composed completely of robot builders and technical people that team cannot exist just like a company cannot exist if it is only made up of engineers. - Garret [more]
Unread 21-01-2005, 11:58
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: USB Joystick to DB15
Originally Posted by team1307
This might be a stupid question but wouldnt it work if we found some way to convert db9 to db15? I know that 6 pins would have to be unused.. Is it a data collision problem?
The problem is that the OI measures voltage from 0 to 5 volts, and turns it into a number from 0-255. You get a variable voltage using a potentiometer, which is what you'll find in the kit-provided joysticks. The problem with modern joysticks is that they give a digital output, sending pulses on a wire. The OI cannot process this sort of signal. Even if you converted the connector to DB9, you'd still be getting the same sort of signal. Your joystick probably uses analog values to generate the digital signals, so if you're feeling courageous, you could open up the joystick, bypass much of the internal circuitry, and wire the potentiometers directly to the proper pins on a DB15 connector. If your joystick uses some fancier sort of sensor (optical, perhaps), it might be a little different. The point is, it's likely that you can get your joystick to work with the OI, but the rewiring you'd have to do would be internal.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
