Go to Post Why aren't the kids who sit alongside the sidelines and observe as valued? Why are they looked upon as leeches, in it for a trip? - Madison [more]
Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Unread 17-01-2005, 17:55
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Example gyro code released.
I've written example gyro interface code and posted it here: http://kevin.org/frc. This code has been substantially revised since the version released earlier with the PID and scripting code. A substantial amount of documentation has also been written to support this code. As the programming interface has changed, this code will not work with the current version of robot.c. An updated version of robot.c will be released soon.
Here's the readme.txt:
The source code in gyro.c/.h contains a driver and supporting
software to interface a variety of inexpensive gyros to your
robot controller. This software was tested with Analog Devices'
ADXRS150EB and ADXRS300EB gyros. Data sheets for these devices
are included. Support for the ADXRS401EB is also included. By
default, this software is configured to work with a ADXRS150EB
gyro, sampling at 400Hz, downconverting to an update rate of
50Hz by averaging eight samples per update. These parameters
can be changed by editing gyro.h.
This software makes the assumption that when it's running, it
solely controls the analog to digital conversion hardware and
that only the gyro, on analog input one, is being sampled.
Calling Disable_Gyro() will disable the gyro software and
allow you to use the ADC for other purposes.
This source code will work with the Robovation (A/K/A EDU-RC)
robot controller and the FIRST Robotics robot controller.
Wiring-up the ADXRS401EB, ADXRS150EB and ADXRS300EB gyro
evaluation boards is straightforward. Grab a PWM cable and cut
off the male end and strip the three wires back a centimeter
or so. With a low wattage soldering iron, solder the white wire
to the RATEOUT pin, solder the black wire to the AGND pin, the
red wire to the AVCC pin, and finally connect a jumper wire
between the AVCC and PDD pins. Plug the female end into the
robot controller's analog input 1.
For optimum performance, you'll need to calibrate the scaling
factor to match that of your gyro's. One way to calibrate your
gyro is to mount it very securely to a hefty, square or
rectangular object. Mounting the gyro to a hefty object will
help dampen higher frequency vibrations that can adversly
effect your measurements. Place the mounted gyro against
another square object and start the included demonstration
software. To get good results, the mount must be absolutely
still when the "Calibrating Gyro Bias..." message appears on
the terminal screen. After a few seconds, the gyro angular rate
and angle will be sent to the terminal screen. If the angle
drifts rapidly while the mounted gyro is motonless, you need
to restart the software to acquire a new gyro bias measurement.
Again, gyros are very sensitive and must be still while the bias
is calculated. Once the gyro is running with little drift,
rotate the mount 180 degrees and note the reported angle. If the
angular units are set to tenths of a degree, the ideal reported
angle is 1800. If set to milliradians, the ideal angle 1s 3142
(Pi times a thousand). For every tenth of a percent that the
angle is high, decrease the GYRO_CAL_FACTOR numerator by one.
Conversly, for every tenth of a percent low, increase the
numerator by one. Repeat until you're satisfied with the
accuracy.
If you find that the Calc_Gyro_Bias() function doesn't do
a good enough job of calculating a bias for your particular
gyro, another option is to average the gyro bias for a much
longer period of time and manually set the gyro bias using
the function Set_Gyro_Bias(). An example that shows how to
do this is commented out in the accompaning user_routines.c/
Process_Data_From_Master_uP(). With a perfectly still gyro,
running this example code will display a running average gyro
bias that should converge to one value over time. Enter this
value into the call to Set_Gyro_bias() and comment out or
remove the call to Calc_Gyro_Bias(). Now perform the gyro
scaling factor calibration described above.
The included project files were built with MPLAB version 6.60.
If your version of MPLAB complains about the project version,
the best thing to do is just create a new project with MPLAB's
project wizard. Include every file except: FRC_alltimers.lib
and ifi_alltimers.lib and you should be able to build the code.
Here's a description of the functions in gyro.c:
Initialize_Gyro()
This function initializes the gyro software. It should be called
from user_routines.c/User_Initialization().
Get_Gyro_Rate()
This function returns the current angular rate of change in
units of milliradians per second. If desired, the angular unit
can be changed to tenths of a degree per second by modifying
the angular units #define entry in gyro.h
Get_Gyro_Angle()
This function returns the change in heading angle, in
milliradians, since the software was initialized or
Reset_Gyro_Angle() was called. If desired, the angular unit
can be changed to tenths of a degree by modifying the angular
Calc_Gyro_Bias()
This function forces a new gyro bias calculation to take place.
For best results, this should be called about a half second
after the robot powers-up and while the robot is perfectly still
with all vibration sources turned off (e.g., compressor). It's a
good idea to call this function whenever you know the robot will
be completely still for about twenty-five milliseconds. For
example, call this function just after you've completed a
straight line drive, and just before doing a turn-in-place.
Get_Gyro_Bias()
This function returns the current calculated gyro bias. For
extra precision, this software internally maintains a gyro bias
value that is the sum of GYRO_SAMPLES_PER_UPDATE samples of the
gyro's analog output. By default, GYRO_SAMPLES_PER_UPDATE is
set to a value of eight in gyro.h
Set_Gyro_Bias()
This function can be called to manually set the gyro bias. For
Reset_Gyro_Angle()
This function resets the integrated gyro heading angle to zero.
Disable_Gyro()
This function should be called when the gyro functionality is
no longer needed, thus reclaiming the time spent servicing the
timer 2 interrupt.
Initialize_ADC()
This function initializes the analog to digital conversion
hardware. This is called by Initialize_Gyro() above and
shouldn't be called directly.
Initialize_Timer_2()
This function initializes and starts timer2. This is called by
Initialize_Gyro() above and shouldn't be called directly.
Timer_2_Int_Handler()
This function is automatically called when timer 2 causes an
interrupt and shouldn't be called directly.
Six things must be done before this software will work
correctly on the FRC-RC:
1) The gyro's rate output is wired to analog input 1.
2) A #include statement for the gyro.h header file must be
included at the beginning of each source file that calls the
functions in this source file. The statement should look like
this: #include "gyro.h".
3) Initialize_Gyro() must be called from user_routines.c/
4) The timer 2 interrupt handler, Timer_2_Int_Handler(), must
be installed in User_Routines_Fast.c/InterruptHandlerLow().
See the accompanying copy of User_Routines_Fast.c to see how
this is done.
5) You must select the gyro you're using from a list in gyro.h
and if needed, remove the // in front of it's #define.
6) For optimal performance, you'll need to calibrate the gyro
scaling factor using the instructions above or those included
in gyro.h.
Eight things must be done before this software will work
correctly on the EDU-RC:
2) IO1 must be configured as an "INPUT" in user_routines.c/
3) The call to Set_Number_of_Analog_Channels() must configure
at least one analog channel.
4) A #include statement for the gyro.h header file must be
5) Initialize_Gyro() must be called from user_routines.c/
6) The timer 2 interrupt handler, Timer_2_Int_Handler(), must
this is done.
7) You must select the gyro you're using from a list in gyro.h
8) For optimal performance, you'll need to calibrate the gyro
in gyro.h.
-Kevin
Kevin Watson
http://kevin.org
Unread 17-01-2005, 22:48
Squall Squall is offline
Squall is an unknown quantity at this point
Re: Example gyro code released.
Thanks a lot! That's all I can say!
Girafales - TEAM #1382
Unread 17-01-2005, 23:35
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Nice! good thing we already ordered our gyro
Once again thankyou for the great code
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 17-01-2005, 23:49
How could I use this with the accelerometer?
Does anyone know the sample rate for it?
Unread 18-01-2005, 19:57
FRC #2429
Has anyone tried this code yet? I'd like to get a sense of how (if) it's working for teams.
-Kevin
Kevin Watson
http://kevin.org
Unread 21-01-2005, 10:02
about_abot about_abot is offline
AKA: Gary Dettmers
#1008 (LugNuts)
about_abot is an unknown quantity at this point
-Kevin
Kevin,
First of all, thank you for your undying effort keeping this huge event on track. I just started this year as a programming mentor and do not know the ins and outs of what has happened over the last few years with the code.
The programming student on the team is new, and he is a little anxious with everything. He first saw "C" just a few weeks ago and is feeling a little overwhelmed. I am guiding him through how to layout the functionality he needs to meet the required game rules and translate all of that into working code.
In one of your previous posts, you stated you were working on a new robot.c (and I hope a new robot.h). Do you have any idea when we would see that? Having that will help immensely since my role is to help and not perform the actual work instead of the student doing it himself.
Respectfully,
Gary D.
Unread 21-01-2005, 11:22
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Kevin,
Is this the same as the edubot guro code you have on your site?
Unread 21-01-2005, 11:30
FRC #2429
As the FIRST folks haven't sent our demobot back for us to test updates on, I'll post the changes (hopefully) sometime this weekend when my team has their 'bot moving around. If you want to make the changes yourself, only two things need to be done to get robot.c to work with the new gyro code:
1) Because I now return angular units expressed in milliradians instead of degrees, line 198 needs to be changed from:
heading = Gyro_Angle()*PI_MRAD/180L;
to:
heading = Get_Gyro_Angle();
2) The programming interface was expanded and many functions were renamed. To fix this, I would just drop the new version of gyro.c/.h into your build directory and let the compiler find the deltas for you (there will only be a few).
-Kevin
Kevin Watson
http://kevin.org
Unread 21-01-2005, 12:49
AKA: Gary Dettmers
#1008 (LugNuts)
to:
-Kevin
Great! Thank you for your help. I will let you know if we get it to work this weekend.
Gary
Unread 21-01-2005, 15:46
FRC #2429
Originally Posted by Jon236
Kevin,
Yes, there's a version with demo code for the EDU-RC and one for the FRC-RC. Both have a common source file that will make it fairly easy to use a gyro. By making the modifications to robot.c above, or waiting for me to update robot.c, you'll be able to drop this improved code into the scripting software.
-Kevin
Kevin Watson
http://kevin.org
Unread 21-01-2005, 15:50
FRC #2429
...I will let you know if we get it to work this weekend.
Cool. I have no idea if people are actually using the code I've published over the last month or so and would very much like feedback on performance, ease of use, etc...
-Kevin
Kevin Watson
http://kevin.org
Unread 21-01-2005, 16:01
Kevin, the gyro code has worked fine for us. We are able to track heading, and stick to a heading. We arent using the scripting, for lack of need.
As soon as we get our encoders in, I will post how the PID works out.
Unread 21-01-2005, 16:14
FRC #2429
Very cool. Which gyro are you using? Which method are you using to calculate the gyro bias? Calc_Gyro_Bias() or the manual method I described? Are you calculating the bias once at startup or are you actively tracking it with frequent calls to Calc_Gyro_Bias()? Sorry, 'bout all the questions, but I'd like to get a sense of how much drift people are seeing from a larger sample of gyros. I have some serious magic that I can throw at the problem if people can't use their gyros because of too much drift.
-Kevin
Kevin Watson
http://kevin.org
Unread 21-01-2005, 16:29
For now, we are using the BEI gyrochip provided in the 2003 kit. This is for testing purposes, seeing as they are illegal for robot use. We are getting gyro bias at startup, with the Calc_Gyro_Bias() function (we plan to poll it more, but we have only done basic tests, seeing how we are learning this as we go). Our gyro use code hasnt really been developed, since we are waiting for our encoder delivery, and we are planning to tackle the PID system all at once. But in our initial tests, we were seeing a bit of drift; The heading would waver about +- 17 milliradians every 8 seconds. (I dont believe we had the scale factor set the right way, seeing as one rotation was giving us a heading of about 10000 mRads.)
In order to keep costs down, I was hoping to use the provided accelerometer in place of a yaw gyro for the bot. Im guesing this would work with the gyro driver you wrote, but is there anything I need to change? (yanno.. something that I would probably never be able to figure out on my own.)
As for the drift, we have explored 2 options. One was to mount the gyro to a piece of foam tape or rubber, hoping it would cut out motor/compressor vibrations. I think the gyro bias is being set incorrectly due to the vibrations, and since for now we are only polling for bias once, it may have ill effect on our code.
Any tips? Thanks.
Unread 21-01-2005, 16:55
FRC #2429
Yeah, you'll need to set the scaling factor before you know how much drift you're seeing. I didn't think to add the old gyrochip as one of the options in gyro.h, but will look into it.
I've already released TI accelerometer code. Here's the post. BTW, you can't use the accelerometer to detect yaw. It's great at measuring pitch or roll, though.
Any tips? Thanks.
Yes, set the scaling factor correctly (I'll try to update gyro.h to include the gyrochip) using the instructions in readme.txt. Then try the manual method I documented in readme.txt (also in gyro.h, I think). I have a ADXRS150EB that, once correctly calibrated, drifts only a few milliradians a minute, which is pretty good.
-Kevin
Kevin Watson
http://kevin.org
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
Wierd gyro code problems...pls help Salik Syed Programming 4 14-03-2004 01:29
Infrared Beacon and Sensor Diagnostics Code Released Kevin Watson Programming 3 25-02-2004 17:50
gyro code odin892 Programming 2 08-04-2003 14:50
