Go to Post You mean nobody else has picked up on the hint about next year's game being called "Whack the Billfred"? - EricH [more]
Unread 21-01-2005, 10:49
RIgnazio RIgnazio is offline
Team Role: Webmaster
RIgnazio will become famous soon enough
Question Using REAL ENGLISH in autonomous mode???
At the kickoff, they were saying that you could use real english to program in autonomous mode, but there is nothing supporting that statement. They said you could do this:
Drive forward 1000mm
Turn left
There is nothing on the CD or in the MPLAB software to enable you to do this, so how does it work?
Unread 21-01-2005, 11:13
Re: Using REAL ENGLISH in autonomous mode???
You'll find the forum discussions on this at:
http://www.chiefdelphi.com/forums/showthread.php?t=32870
The scripting code is located at http://kevin.org/frc/
Unread 21-01-2005, 13:28
Unhappy Re: Using REAL ENGLISH in autonomous mode???
I looked at all of that, and then I went to www.kevin.org/frc and there was nothing about using the plain english to run the controller. Please help. I will look at the link you gave me again, hoping for an answer.
Unread 21-01-2005, 13:35
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
I think you're misunderstanding exactly what it is they're providing. In the navigation code on the kevin.org site, you will find a file called "commands.h" that contains this:
struct commands command_list[] = {
/*   Command              parm 1     parm 2   parm 3   */
{CMD_GYRO_BIAS,               0,        0,      0},
{CMD_WAIT_FOR_BUMP,         100,        0,      0},
{CMD_WAIT,                 1000,        0,      0},
{CMD_TURN,       -1571L,      100,      0},
{CMD_TURN,        1571,      100,      0},
{CMD_JUMP,                    1,        0,      0},
{NULL,                        0,        0,      0}
{CMD_DRIVE,                1500,        0,      0},
{CMD_WAIT,                 4000,        0,      0},
{CMD_TURN,       (-1500),       50,      0},
{CMD_WAIT,                 3000,        0,      0},
{CMD_DRIVE,                2400,        0,      0},
{CMD_TURN,        (PI_MRAD / 2),       50,      0},
{CMD_DRIVE,                   0,        0,      0},
{CMD_KEEP_HEADING,       240000,      100,      0},
{NULL,                        0,        0,      0}
This scripting language is what they were referring to at kickoff. It's not "plain english" but it's much closer than regular C code .
Unread 21-01-2005, 13:38
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Well, Dave Lavery stretched the truth a bit when he said it was plain english. Your:
Turn left
would be
{CMD_DRIVE, 1000, 0, 0},
{NULL, 0, 0, 0}
in commands.h
Zan Hecht
Unread 21-01-2005, 13:43
Code\\Pilot Code\\Pilot is offline
< Only smart people see my avatar
AKA: Rafael Estrada
FRC #1065 (Tatsu)
Code\\Pilot is an unknown quantity at this point
Send a message via AIM to Code\\Pilot Send a message via MSN to Code\\Pilot
{NULL, 0, 0, 0}
in commands.h
So if i want to use that in autonomous, do i just write that in the autonomous part in user_routines_fast.c?
Join the Red revolution, give me some RED rep!!!!
if it doesn't work, don't force it. Go get a bigger hammer.
int run = 0;
int robot_chasing_you = 1;
if (robot_chasing_you)
run = 254;
I got 48 Gmail invites left, pm me with your e-mail so i can send you one.
Unread 21-01-2005, 13:45
Thank you both for your help. What I did not understand is where these commands were being called from. I have one last question: With gyro.c/h and commands.c/h, how does it know which PWMs your motors are on? Yes, your robot could get bumped, but if your drive motors are on PWM3 and PWM4 and it is trying to control PWM1 and PWM2, how would it know?
Unread 21-01-2005, 13:46
Yes. I knew you could do that all along, but I was having problems understanding where it was calling it from which I now know as commands.h, and what PWM it is controlling.
Unread 21-01-2005, 14:12
Bharat Nain's Avatar
On your OI board, you have the pins indicating which pwm you are plugging your motors into. In the program you specify the pwms you are sending the signal to.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 21-01-2005, 16:23
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Actually, we have some code that includes far more complex commands that we may or may not release in the future. Right now I'm working on the "CMD_ORDER_MORE_PIZZA" command. For a laugh, last night we used the newly finished "CMD_STOP_AND_CATCH_FIRE" command on some unsuspecting freshmen <evil grin>.
-Kevin
Kevin Watson
http://kevin.org
Unread 21-01-2005, 20:14
Arrow Re: Using REAL ENGLISH in autonomous mode???
NICE!
If only those really worked, I would love it. Just somehow hook a Cordless phone to a PWM in and PWM out, and have it actually call Pizza Hut and order a pizza. I wonder if they accept digital robot money
But I am still wondering how it knows which PWM to control. It is set in the program, but where? Unless it is COMPLETELY different from EDU Programming, as that is all I really have experience with, as this is my rookie year.
Unread 21-01-2005, 20:27
FRC #2429
From the pid.h file:
/* Define your pwm values for the left and right wheels. */
#define wheel_l pwm01
#define wheel_r pwm03
-Kevin
Kevin Watson
http://kevin.org
Unread 21-01-2005, 21:24
Thanks
Unread 16-02-2005, 19:54
Moloch's Avatar
Moloch Moloch is offline
Moloch can only hope to improve
So....your supposed to be able to just type in user_routines_fast.c :
{NULL, 0, 0, 0
and your auto works??
Unread 17-02-2005, 17:19
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
{NULL, 0, 0, 0
No. Technically speaking, the script is read, not executed. If you look through the navigation code (specifically, robot.c and robot.h), you will find that it is actually a large conglomeration of a bunch of state machines.
The sample script is in commands.h. There is no commands.c.
A little question about the autonomous mode Anton Programming 4 18-01-2005 14:08
Wolrd Triple Play Autonomous Mode (WAM) Standards Natchez General Forum 3 11-01-2005 15:52
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
