Go to Post In FIRST you have the right to remain silent, anything you say can and will be held against you and your associates in the court of public opinion. - Koko Ed [more]
Unread 21-01-2005, 14:12
Bharat Nain's Avatar
Re: Using REAL ENGLISH in autonomous mode???
Originally Posted by RIgnazio
Thank you both for your help. What I did not understand is where these commands were being called from. I have one last question: With gyro.c/h and commands.c/h, how does it know which PWMs your motors are on? Yes, your robot could get bumped, but if your drive motors are on PWM3 and PWM4 and it is trying to control PWM1 and PWM2, how would it know?
On your OI board, you have the pins indicating which pwm you are plugging your motors into. In the program you specify the pwms you are sending the signal to.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
A little question about the autonomous mode Anton Programming 4 18-01-2005 14:08
Wolrd Triple Play Autonomous Mode (WAM) Standards Natchez General Forum 3 11-01-2005 15:52
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
