Go to Post Teams should spend more time talking about how to avoid penalties during their strategy sessions. - Rob [more]
Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Unread 21-01-2005, 16:55
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Re: Example gyro code released.
Originally Posted by Tom Bottiglieri
For now, we are using the BEI gyrochip provided in the 2003 kit. This is for testing purposes, seeing as they are illegal for robot use. We are getting gyro bias at startup, with the Calc_Gyro_Bias() function (we plan to poll it more, but we have only done basic tests, seeing how we are learning this as we go). Our gyro use code hasnt really been developed, since we are waiting for our encoder delivery, and we are planning to tackle the PID system all at once. But in our initial tests, we were seeing a bit of drift; The heading would waver about +- 17 milliradians every 8 seconds. (I dont believe we had the scale factor set the right way, seeing as one rotation was giving us a heading of about 10000 mRads.)
Yeah, you'll need to set the scaling factor before you know how much drift you're seeing. I didn't think to add the old gyrochip as one of the options in gyro.h, but will look into it.
In order to keep costs down, I was hoping to use the provided accelerometer in place of a yaw gyro for the bot. Im guesing this would work with the gyro driver you wrote, but is there anything I need to change? (yanno.. something that I would probably never be able to figure out on my own.)
I've already released TI accelerometer code. Here's the post. BTW, you can't use the accelerometer to detect yaw. It's great at measuring pitch or roll, though.
As for the drift, we have explored 2 options. One was to mount the gyro to a piece of foam tape or rubber, hoping it would cut out motor/compressor vibrations. I think the gyro bias is being set incorrectly due to the vibrations, and since for now we are only polling for bias once, it may have ill effect on our code.
Any tips? Thanks.
Yes, set the scaling factor correctly (I'll try to update gyro.h to include the gyrochip) using the instructions in readme.txt. Then try the manual method I documented in readme.txt (also in gyro.h, I think). I have a ADXRS150EB that, once correctly calibrated, drifts only a few milliradians a minute, which is pretty good.
-Kevin
Kevin Watson
http://kevin.org
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
Wierd gyro code problems...pls help Salik Syed Programming 4 14-03-2004 01:29
Infrared Beacon and Sensor Diagnostics Code Released Kevin Watson Programming 3 25-02-2004 17:50
gyro code odin892 Programming 2 08-04-2003 14:50
