Go to Post We didn't need a championship to recognize the kids on our [little league] team and we sure didn't need one to inspire them. If you want to go to the championships then work harder, don't try and lessen the value of the championships by letting everyone in. - FarmerJohn [more]
Unread 20-01-2005, 19:53
Crazy's Avatar
Crazy Crazy is offline
None #0461 (Westside Boiler Invasion)
Team Role: Driver
Crazy has a spectacular aura aboutCrazy has a spectacular aura about
Send a message via AIM to Crazy
Parameters [Dimensions] for the controls?
Does anybody know the actual parameters for the Operator interface and the Joysticks? Thanks.
"I guess that's why they call you Crazy!"
Unread 20-01-2005, 21:20
Re: Parameters for the controls?
It sounds like you could use some time reviewing the Operator Interface documentation available on the IFI Robotics web site. Page 5 gives a good summary of what you can connect to it.
Unread 21-01-2005, 11:50
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Here's the wiring data on the ***OLDER*** CH Flightsticks, to see how they map out relative to standard PC Joysticks. You can use this as a basis for understanding how other standard PC joysticks would work with the OI.
The CH Products Flightsticks are using the old DB-15M PC Joystick standard. They are NOT USB, so don't try to buy a USB stick to work with the OI.
- Full Forward, Full Left and Thumbwheel forward are lowest resistance settings.
Someone please correct me if I'm wrong, but I *think* that translates to minimum byte values in the default program...
- All three pots are roughly 90K +/- 5%, run in "Rheostat Mode", with one end of the main element being the "signal", and the wiper tied to +5V on pin 1. (seems backward to me, but the pot doesn't care...) Any 100K pot based joystick wired in this way will be an acceptable equivalent.
PC Joystick Standard equivalency:
- Left/Right (X) signal = "PC Joystick Pot X1" on pin 3.
- Forward/Back (Y) signal = "PC Joystick Pot Y1" on pin 6.
- Thumbwheel = "PC Joystick Pot Y2" on pin 13.
- All switches are commoned to both pins 4 and 12 (two of the three standard PC switch grounds). Note this does NOT exactly conform to the PC Joystick Standard, but since most manufacturers tie all three grounds together anyways, it normally doesn't matter.
- Trigger switch = ""PC Joystick Switch 1" on pin 2.
- Top Hat switch = "PC Joystick Switch 2" on pin 7.
- The cable is shielded, and terminated only on the case of the DB-15M connector.
- All other pins unconnected.
The PC Joystick Standard:
Pin: Signal
1: XY1 (+5V)
2: Switch 2
3: X1 (pot)
4: Ground (for Switch 1)
5: Ground (For Switch 2)
6: Y1 (pot)
7: Switch 2
8: N/C (Not Connected)
9: XY2 (+5V)
10: Switch 3
11: X2 (pot)
12: Ground (3&4)
13: Y2 (pot - In this case the Thumbwheel)
14: Switch 4
15: N/C
I haven't checked out the NEW sticks yet to see which is which, but I'm sure at LEAST the X/Y (main stick) pots and the trigger are the same connections.
If someone has already reversed engineered the new sticks, please post their wiring diagram here. Thanks!
I hope this helps!
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Unread 21-01-2005, 15:37
Logan Byers Logan Byers is offline
Roaming Mentor & Referee
no team (Team Indiana)
Logan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud of
I'm sorry, but we must have worded the question wrong...
What are the dimensions for the controls and OI?
Sorry for the miswording/confusion...
Unread 21-01-2005, 15:47
Again, everything you need should be on the IFI web site. You want the Operator Interface Installation Info document.
Unread 21-01-2005, 17:18
Unhappy Re: Parameters [Dimensions] for the controls?
Again, another misunderstanding and/or mis-wording. We need the dimensions for the entire controls not the Operator interface.
I am truly sorry if I am causing confusion or misunderstanding.
Unread 21-01-2005, 17:24
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Are you looking to see how large you can make your control unit, [including oi, joysticks and anything else] to where it still fits on the driver stations shelf?
-Michael Dessingue
Unread 21-01-2005, 22:09
That is correct.
Unread 21-01-2005, 22:17
O-H
FRC #0048 (Delphi E.L.I.T.E.)
69" x 12" (unless you want the controls to overhang the table a little bit).
<R65> The Operator Interface Console designed by your team must fit on the 69" wide by 12" deep shelf in the Alliance Station and the radio modem connected to the Operator Interface must be able to reach the mounting bracket on the operator stations. Be sure to leave at least 48" of slack in the 9-pin cable.
Unread 21-01-2005, 22:23
Thank you for answering our question. We weren't sure if that was it (our Electronics team this year hasn't worked with electronics until this year.). Thank you very much!
1992 Controls Venkatesh Electrical 6 03-10-2004 22:04
[FVG]: Controls Round C1 Mike Ciance FIRST-related Organizations 18 29-07-2004 20:44
