Go to Post Is Atlanta an Indian word for "take the longest path between two places"? - Klondike Mike [more]
Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Unread 21-01-2005, 22:10
neilsonster's Avatar
neilsonster neilsonster is offline
AKA: Andrew Neilson
FRC #0772 (Sabre Bytes)
neilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to all
Send a message via MSN to neilsonster
Re: Example gyro code released.
For now, we are using the BEI gyrochip provided in the 2003 kit. This is for testing purposes, seeing as they are illegal for robot use.
Where did you hear they are illegal? Check the Q&A under ID 1118:
Q: Can we use Gyros from previous year's kits on our robot?
A: Yes as long as it passes the 2005 Part Use Flowchart and you account for its cost according to the cost accounting rules.
EDIT: Nevermind... I guess the Q&A people didn't look up the price...
Unread 21-01-2005, 23:10
Originally Posted by neilsonster
There shouldn't be a problem with you using the gyrochip on your robot.
Sweet, thanks for the info. I was under the impression it was illegal seeing as it was up for sale in a FIRST yard sale.
Unread 22-01-2005, 00:16
Kevin Watson's Avatar
La Caņada High School
FRC #2429
I've updated the gyro code to include scaling factors for the two different BEI GyroChip gyros that FIRST has included in the KOP in the past. The code can be found here: http://kevin.org/frc.
-Kevin
Kevin Watson
http://kevin.org
Unread 22-01-2005, 00:45
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
I don't believe that the BEI gyro's are legal because the lowest price I have been able to find them for is approximately $350 which over the $200 price limit for additional electronics. If anyone has seen a gyro for sale cheaper then that, that would follow the vendor requirements that FIRST has laid out please post a link because I have 3 of them sitting in the shop that I would love to use on this years robot.
Unread 22-01-2005, 10:46
kutty18 kutty18 is offline
#0234 (Cyberblue)
kutty18 is on a distinguished road
Send a message via AIM to kutty18 Send a message via Yahoo to kutty18
Originally Posted by Kevin Watson
I have some serious magic that I can throw at the problem if people can't use their gyros because of too much drift.
Hmmm..Magic?...We tried to calibrate the gyro, but there was too much drift. We mounted it to a square piece of wood, but we still had too much drift. Is there any way to control the drift?
Thanks
Unread 22-01-2005, 12:02
FRC #2429
Thanks
What kind of gyro are you using? Did you try the manual method that uses Set_Gyro_Bias()? Just make sure the gyro is motionless as the bias is being calculated.
-Kevin
Kevin Watson
http://kevin.org
Unread 22-01-2005, 12:08
#0234 (Cyberblue)
-Kevin
We are using ADXRS300ABG & ADXRS300EB-ND Gyros. Yes we tried the manual method that uses Set_Gyro_Bias()?
Unread 22-01-2005, 12:13
FRC #2429
How much drift are you seeing (you need to calibrate the scaling factor first).
-Kevin
Kevin Watson
http://kevin.org
Unread 22-01-2005, 12:19
AKA: Andrew Neilson
Ok, I just looked into this as well and you're right. The darn things are too expensive! (now we need to buy a new gyro..)
Edit: Actually, on second thought, does anyone know for sure if the fact that FIRST gave it to us in previous years makes a difference?
Unread 22-01-2005, 12:26
#0234 (Cyberblue)
The values for "rate" and "angle" are empty in the terminal window. Once in a while, "angle" is 0. When we manually set Bias, the values for "rate" and "angle" are gibberish...Also, sometimes, the dreaded "windows fatal error" screen comes up. We have followed the steps that was in the readme.txt file. And no changes to the code were made...except for, changing to the right gyro model #.
Unread 22-01-2005, 13:19
FRC #2429
I think you'll need to find a different windows machine to use before you'll be able to make any progress.
-Kevin
Kevin Watson
http://kevin.org
Unread 22-01-2005, 17:53
#0234 (Cyberblue)
Hey, thanks. We got it to work. We took it to a "quiet" place, and it worked fine. Maybe its those machines that messed it up...
Unread 23-01-2005, 10:37
AKA: Brad
#0190 ( Gompei and the Herd)
-Kevin
We used the code with the ADXRS300 as well and were seeing about 8 degrees of drift over 2-1/2 minutes on a motionless robot. We modified the code to average the bias over more than a single group of samples and increased the sample size to 16 to get the extra precision. That seemed to improve the results.
Can you tell us what you were seeing for drift over time? I just wasn't sure what to expect for results and so we tried these modifications.
Also, I have a question. You're locking the A/D onto Channel 1 to presumably eliminate that acquisition time when switching channels. How much time does actually take (for teams that want more than one analog input)?
And do you know what the conversion time is once the channel is switched?
Thanks again for posting the code.
Brad
Unread 23-01-2005, 13:36
FRC #2429
Without actively tracking the bias, you're getting performance that is about what I would expect from a ADXRS300. I'd be pretty happy with a gyro that only drifted a degree over the entire autonomous period. For reference, I have a ADXRS150EB that drifts a degree over about a minute and I tested an old GyroChip that did even better.
No, I take control of the ADC hardware because I'm trying to be pretty efficient and not use up a lot of CPU time. You'll notice that in response to the timer interrupt, I read the ADC result register and then immediatly start another conversion. If you used the ADC after my conversion was done, I'd have lost the conversion result the next time the timer interrupt fires off. One way around this is to increase the timer interrupt rate and interleave the ADC measurements.
I'm sure it's considerably less time than the timer interrupt period, but I don't know the exact value. The data sheet would be a good document to consult for this information.
-Kevin
Kevin Watson
http://kevin.org
Unread 23-01-2005, 13:38
-Kevin
Is it possible for us to use the ADC for say.. another gyro?
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
Wierd gyro code problems...pls help Salik Syed Programming 4 14-03-2004 01:29
Infrared Beacon and Sensor Diagnostics Code Released Kevin Watson Programming 3 25-02-2004 17:50
gyro code odin892 Programming 2 08-04-2003 14:50
