Go to Post Hasn't that always been the mission of FIRST? Don't settle for what works; strive for what amazes. - Sam Lipscomb [more]
Unread 20-01-2005, 13:59
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Lightbulb FYI about using PWM 13-16 with interrupts
Here's what I posted to Innovation FIRST and their answer.
Question:
In the original default code, for the v2.2 compiler, PWMs 13-16 use a generate function to control the PWMs. How does this function work and what exactly does it do? How are PWMs 13-16 different from PWMs 1-12? I am asking this because yesterday we were testing our modified default code using optical encoders connected to the digital I/O pins. The wierd thing that happened was that as the encoders were rotated faster (about 900rpm attached to a cordless drill) the drive wheels started rotating. I looked through the code and did not see any other function other than the generate function that calls pwms 13-16. For now we just changed our drive wheels to operate off of PWM 9-12 and the wheels do not turn by themselves when the encoders are rotated really fast.
Also, is there a reason why the default code used with the camera uses pwm 11 and 12 while the default code without the camera uses pwms 13-16? Is this similar to the issue I am having now?
Answer:
The PWM outputs 1 - 12 are handled by the Master microprocessor. PWM outputs 13 - 16 are generated via the user code. All four of these PWMs get generated within 2ms at a 26.2 ms rate. These PWMs are susceptible to interrupt interference. PWM signals have 255 steps and each step is ~5us. Since interrupts have at least a 5us latency, they will stretch a PWM signal up to the amount of time it takes to process the interrupt. So if your user code is processing interrupts at a high rate or your interrupt routines are long, the pwm signals on outputs 13 – 16 could be modified/stretched to create a forward condition on a motor. PWM outputs 13 – 16 should be avoided if user code is interrupt intensive.
My thoughts: I guess that's why most people don't use pwm 13-16
Unread 20-01-2005, 16:30
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: FYI about using PWM 13-16 with interrupts
Can someone verify this? I believe (though could be wrong) that the generate PWMs function just gives it to the hardware, and that handles it.
If I'm wrong, I guess we have ourselves 4 more digital outputs.
Unread 20-01-2005, 17:38
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Yes, I noted some general wackyness in PWM13-16 last year and mentioned it in the IR beacon tracking FAQ.
-Kevin
Kevin Watson
http://kevin.org
Unread 20-01-2005, 23:50
Electrical Engineer
Rookie Year: 1995
Team 177 also abandoned PWMs 13-16 last year for the same reason.
Note to self: Use PWM16 to power camera!
Mike Betts
As easy as 355/113...
Unread 21-01-2005, 07:09
MarkVH's Avatar
MarkVH MarkVH is offline
AKA: Mark VanHaitsma
FRC #0288 (RoboDawgs)
MarkVH is on a distinguished road
I am using the default code and it is sending the same value to pwm13 ,. 14 , 15 , and 16. Any ideas on how to fix it? Right know on the test robot I have 2 mootars wired backward to get it to go straight when the joystick is in the forward positon.
Unread 21-01-2005, 08:05
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
PWMs 13-16 appear to be bit-banged. We had trouble with them last year. If an interrupt occurs while the generate_pwms function is running, the pulse width will be lengthend (or shortened, depending on the part of the cycle you're in) by the amount of time that the uC takes to handle the interrupt. We moved the generate_pwms call to the very last thing that happened each loop - this solved the problem.
Unread 22-01-2005, 00:54
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
The CCP module on the PICs generates a pwm signal that is variable in the duty cycle. The kind that the victors and servos use is variable in the pulse width. (sounds similar, but they are different) So the pwm signal would have to be generated in software, since the hardware isn't suitable for what we need.
But like you pointed out, nothing that careful programming can't resolve.
Assistance for First-Year Teams - MOEmentum: FYI Mr MOE General Forum 0 13-01-2005 17:01
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
