Go to Post We want to go out and build something right away. But it is better to think a little bit first. - ChrisH [more]
Unread 21-01-2005, 20:16
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Questions on Muffin Fans
Would anyone happen to know (or be able to measure for me) the center-to-center distance (across, not diagonal) of the mounting holes on the small muffin fans? Units in mm would be good. Also, are we allowed to use different muffin fans? If so, can we use a 6V one wired to the 12V circuit or would that be bad/disallowed? Thanks.
Unread 21-01-2005, 20:21
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: Questions on Muffin Fans
I can't exactally remember the size of the holes in the muffin fan. Are you talking about the large ones? If so it was around 4 inches, but don't take my word for it.
Running a 6v muffin fan on a 12v source would make that thing spin crazy fast, i've done it before, it doesn't have any real problem except the fact that it'll wear out/die a lot faster.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 21-01-2005, 20:30
KVermilion's Avatar
KVermilion KVermilion is offline
... clearly ...
#0649
KVermilion is infamous around these parts
The muffin fans are measured so that each side is the dimension given.
IE a 120mm muffin fan should be a 120mm square...
Simple geometry from there....
sqrt((120^2) + (120^2)) = 169.705627 =~ 170mm
Unread 21-01-2005, 20:58
The above posts don't really get me the answers I need. Can someone with the actual small muffin fan measure it, or someone who has the Inventor model measure it in there? And can someone who is knowlegable on the rules tell me if we can use a 6V fan? Thanks.
Unread 22-01-2005, 01:41
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
I dont have the fan in front of me, it somehow dissapeared, but I have to ask why do you wish to use a 6 Volt fan when 12 Volt fans are included? I dont believe there would be a problem with using the 6 volt fans except that they will burn out quicker, possibly in the middle of running a match or something which at that point your fets ( or whatever they are ) could get overheated.
Use the flow chart to see if you can use it and if it doesn't put your electronics budget over then you could use it.
-Mike
Unread 22-01-2005, 02:07
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
If they are standard 40mm x 40mm fans (which I am almost 100% sure they are) the center to center distance (not diagnally) is around 32.5mm.
EDIT: Andy's original shifting tranny had these mounted on it. That PDF should have the hole spacing too!
EDIT 2: Looks like he has it at 1.265", which confirms the 32.5mm within some uncertainty. A 4-40 should have plenty of wiggle room
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 22-01-2005, 10:57
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
A fan has a motor, so unless you can find explicitly otherwise I would assume that it must be a kit motor driving it or no go.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
47 Questions! Matt Krass Games/Trivia 52 19-04-2006 00:58
**FIRST EMAIL**/Autodesk Inventor Training and Technical Questions Information Rich Wong FIRST E-Mail Blast Archive 0 07-12-2004 17:22
Muffin Fans lizs702 Technical Discussion 1 21-02-2004 12:26
Muffin fans .. Mike Hendricks Electrical 4 19-02-2004 19:26
GO Marlins! Tytus Gerrish Chit-Chat 26 17-10-2003 20:44
