Go to Post I think candids are my best... I'm sneaky with my 12X optical zoom. - MissInformation [more]
Unread 20-01-2005, 14:16
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Question SMC pneumatic manifolds
This question goes out to teams 60, 254, or any other team that has used/will use a pneumatic manifold. What is the SMC part number of the manifold that will work with the double solenoids/single solenoids that were given out this year? Is the right part number for the manifold: SS5Y3-20-xx where xx is the number of ports on the manifold. In the catalog for this part, it also lists that a blank plate assembly is needed? Is this to cover the unused ports on the manifold? What part number whould this have?
Thanks for the help!
Unread 22-01-2005, 02:20
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: SMC pneumatic manifolds
ss5y3-41-xx-n7 (or n7t) is the part you need. We have been in contact with SMC, and it looks like the ONLY ones available in a 1/4" fitting size are the 9-port ones. Last I heard there were ~9 available in San Jose, CA.
n7 or N7t refers to the fitting size. It doesnt make alot of sense, but It means 1/4" tubing, and as such, the corresponding 1/8" NPT threads for 1/4" tubing on the pressure input and exhaust outputs
41 refers to base mounted, meaning the manifold itself has the quick disconnect fittings on it.
sy3000-26-9A is the blanking station kit used to seal off any unused ports. The things dont weigh very much, so having the 9-port and a few blanking stations is not all that much extra weight. Maybe a few ounces, max.
I would reccomend signing up for SMC's e-tech catalog. It shows you 3D images of the parts with exact part numbers etc, it is really cool.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
SMC Distributors cabbagekid2 Pneumatics 0 18-01-2005 17:25
Pneumatic Mounting with Zipties? ungulation General Forum 11 24-02-2004 00:51
Pneumatic valves in 2004 Kit gburlison Pneumatics 2 13-01-2004 12:49
SMC Double Solenoid Valve Assembly Dave Kempskie Pneumatics 0 29-01-2003 13:34
SMC Accumulator & Cylinders archiver 1999 3 23-06-2002 22:06
