Go to Post FIRST loves robot heroes. - Rick TYler [more]
Unread 19-01-2005, 12:56
psychoCHIPMUNKK's Avatar
psychoCHIPMUNKK psychoCHIPMUNKK is offline
Technical Manager
#0241 (Last Minute Fix)
Team Role: Driver
psychoCHIPMUNKK has a little shameless behaviour in the past
Send a message via AIM to psychoCHIPMUNKK Send a message via Yahoo to psychoCHIPMUNKK
Exclamation Emergency Vic 884 Help Needed
We've got a slight problem with our test frame. We've built the kitbot and were attempting to wire it, but for some reason our 2 new 884s will only flash orange. The other 2 old ones work fine. We've replaced the cable 3 times (it's one of the yellow split ones) and switched the port around, and for some reason it still wont work. We've taken the tabs off the new ones, and made sure they're in far enough, but nothing has worked yet. Does anyone know what to try next?
Team 241
Unread 19-01-2005, 13:07
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: Emergency Vic 884 Help Needed
Try a straight PWM cable from the RC, and make sure when you pull it out that the pins look straight. If they arn't when you pull the cable out, that means the pins arn't going in the socket correctally. Otherwise, call IFI and get them replaced, but its pretty unlikely that you have a bad one, much more likely one of the pins just isn't going in straight.
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Make sure you read through the User's Manual and Installation Info documents from IFI. One of the suggestions they make is this:
Indication: Flashing ORANGE indicator on power up.
Problem: No PWM signal.
Possible Solutions:
1. Ensure the transmitter and receiver are powered ON.
2. The PWM cable may be improperly connected. Check wire color-coding at each end. Check that the connector is not off a pin at the receiver end.
3. Check for a good PWM signal by connecting a known good servo to the PWM extension cable. If the servo does not move, this can indicate either:
a) a faulty receiver
b) an improperly connected cable
c) a bad PWM extension cable
Note: The servo requires that 5V be present on the center pin of the PWM cable. This connection is not required for the Victor.
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 19-01-2005, 13:16
Technical Manager
Team Role: Driver
Thanks for the quick responses. It got even more complicated. For some reason, now a single cable will run a single 884, but when we connect the Y cable and one 884, it works, however, when we connected the other vic to the Y cable, the first vic stopped getting a signal and the second started getting the signal instead, without moving or removing the cable from the first vic. This is getting very odd...
Team 241
Unread 19-01-2005, 18:10
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Do you have a low battery?
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 19-01-2005, 21:41
We just hooked up our new 884s on our "official" testbed 'bot today. They weren't getting a PWM signal, just sitting there flashing orange. We spent a while making sure the RC was putting out signals correctly, using a servo to verify that the outputs were doing what we expected.
I finally noticed that one of the PWM cables was plugged in backwards, and in the process of correcting that I discovered that none of them had been inserted far enough. They went in with a very firm "click". Now they work fine.
Though you say they're in far enough, your symptoms are consistent with the PWM cables not being solidly connected. Try applying just a little more force than you think you need to when you plug them in.
Unread 19-01-2005, 23:53
Jonathan Brain Jonathan Brain is offline
Jonathan Brain is an unknown quantity at this point
Our team finished wiring our bot a few days ago, and we ran into the same problem, we switched the PWM cables and some victors would work, then switched other PWMs and the ones that worked before wouldn't. I don't know exactly what was wrong with them, just that after a good half an hour of switiching PWM cables, we got them all to work. I would say that they aren't in enough, that would be the only explanation, atleast for ours. But anyways, we haven't run into any problems with the victors cutting off in our rigorous testing.
Good Luck
Unread 21-01-2005, 19:38
Shu Song's Avatar
Shu Song Shu Song is offline
Melodious Footware
AKA: *Crash!* Shuuuuuuuuuuuu
FRC #0639 (Code Red Robotics)
Shu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud of
Send a message via AIM to Shu Song
We are having this problem as well. Though ours is even stranger. We hooked up a victor for the first time and it worked... for about two days. after that, we unplugged the pwn cable and put it back just minutes later and all the victor would do is blink orange.
We hooked up a servo to that cable and the servo worked fine. So through some sort of "magic" by one of our engineers bending a pin, the victor worked again.
But today, we hooked the victor up again and, surely enough, it didn't work, still blinking orange. But this time, when we hooked up the servo again, the servo wouldn't work. We finally switched a victor and the connection was working again.
This is a very peculiar problem. I must say that these victors are really bad this year. No labels, pieces of plastic sticking out of the pwm connection, and now this... oy.
Code Red Robotics - Team 639
Ithaca High School| Ithaca | New York | USA | Earth | Sol System | Milky Way | Universe | Some Alien's Locker
WINNER of the 2005 Finger Lakes Regional, thanks to teams 191 and 494.
WINNER of the 2004 Canadian Regional, thanks to teams 33 and 1112
WINNER of Delphi: Driving Tomorrow's Technology Award at the 2007 Finger Lakes Regional.
Unread 22-01-2005, 10:54
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
I wouldn't say your victors are bad yet you may have a bad cable. One of the crimps to the pins may be loose or you may have a broken internal wire. Either way if you move the cable a little bit one way you may make a full connection while if its moved any other way the connection is not there it theres no pwm signal so you get the blinking orange light. I would say to try a cable that is brand new or one that works for sure, and make sure when you put it in, it goes in all the way [this may require a little force].
-Michael Dessingue
Unread 22-01-2005, 11:33
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
I must admit, I'm feeling the same way as you. Especially about the lack of labeling. I've used the Victors enough that I pretty much know by heart what goes where, but there's plenty of new students on the team, and I'm sure plenty of new rookie teams, who have never seen a Victor before, and pick thme up and wonder what goes where.
The biggest problem by far though is the sheath that you have to file down. It has good intentions, yes, but it took us at least half an hour to get the PWM connectors properly seated in the Victor, because we'd either bend pins or it wouldn't fit in at all. What happened to the Victor 883's with no sheath, so much easier to just use some hot glue...
The plus side is that once you get the PWM connector in, it doesn't seem like it's going to be moving very far, just don't plan on making five second repairs in the middle of the finals, because it'll take you quite some time to replace a victor this year.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 22-01-2005, 11:36
Charly's Avatar
Charly Charly is offline
AKA: Ricardo Martins
#0714 (Super Panthers)
Team Role: Electrical
Charly is an unknown quantity at this point
Send a message via AIM to Charly
Wow quite strange occurrences. The only thing that slowed me down when hooking up the speed controllers were the little annoying pieces of plastic in the PWM sockets. After I removed those they went in just fine and work perfectly.
Team 714 Robotic Design Captain/Electrician
Winners of the 2004 New Jersey Regional Chairman's Award!
Competitions we'll be attending in 2005: NJ Regional, Florida Regional, Championships!
We fried an 884 Andrew Electrical 13 17-08-2003 23:02
