Re: Encoder Hookup
A mechanical encoder typically has three pins: a phase A, a phase B, and a common. When wiring up an encoder to the RC, you would connect the phase A and phase B to two separate digital inputs, and then connect the common to +5. Optical encoders has a similar pinout, but with a connection for ground, too. Kevin Watson (http://kevin.org/frc) has an example of how to read an encoder in programming, but I'm guessing from the terminology that you used that you've already seen this code. I couldn't really understand what you were asking, but I hope that answers your question.
| Rotary Encoder (optical etc.) | Gary C | Technical Discussion | 4 | 16-01-2005 18:23 |
| encoder vs. motor | stephenthe1 | Programming | 55 | 06-01-2005 22:07 |
| Updated Encoder Code Available | Kevin Watson | Programming | 2 | 04-01-2005 01:00 |
| Choosing an Encoder for the Drive-train | MikeDubreuil | Electrical | 11 | 21-10-2004 00:50 |
| how to add steps in the provided encoder program for the edu | Zaramel2002 | Programming | 3 | 11-02-2004 08:35 |
