Go to Post Bring on the competition! And of course the dancing. :D - booton [more]
Unread 22-01-2005, 11:51
Chris.Steimel Chris.Steimel is offline
FRC #0302 (Dragons)
Team Role: Operator
Chris.Steimel is an unknown quantity at this point
Build Error
Been a while since I used C++. I searched the threads with you search option and didn't find any similar errors. Can someone please tell me in plain English what
"Couldn't locate build tool. Check tool locations.
BUILD FAILED: Sat Jan 22 11:47:46 2005"
means. Then tell me how to fix it, cause I have no idea what I'm doing.
Unread 22-01-2005, 11:56
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Build Error
Have you installed the compiler? Remember that you need both the compiler and the IDE to compile your code. If you have, go to Project->Build->Project in the menu bar of the IDE, and make sure that all the paths are correct.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 22-01-2005, 13:37
FRC #0302 (Dragons)
Team Role: Operator
Re: Build Error
Re-installed everything in correct order (according to other team members) and am now getting new errors, any updates to the code I should know about, I'll copy the entire message:
"Clean: Deleting intermediary and output files.
Clean: Deleted file "H:\C Programming\EDU_Default_02-16-04\EduCode\ifi_utilities.o".
Clean: Deleted file "H:\C Programming\EDU_Default_02-16-04\EduCode\main.o".
Clean: Deleted file "H:\C Programming\EDU_Default_02-16-04\EduCode\printf_lib.o".
Clean: Deleted file "H:\C Programming\EDU_Default_02-16-04\EduCode\ifi_startup.o".
Clean: Deleted file "H:\C Programming\EDU_Default_02-16-04\EduCode\user_routines_fast.o".
Clean: Done.
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_utilities.c" -fo="ifi_utilities.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "main.c" -fo="main.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "printf_lib.c" -fo="printf_lib.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
File 'printf_lib.o' could not write COFF symbol table.
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_startup.c" -fo="ifi_startup.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "user_routines_fast.c" -fo="user_routines_fast.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "user_routines.c" -fo="user_routines.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
H:\C Programming\EDU_Default_02-16-04\EduCode\ifi_picdefs.h:1083:Error: syntax error
Halting build on first failure as requested.
BUILD FAILED: Sat Jan 22 13:27:28 2005"
Fun, fun, fun. I wish I understood what it was trying to tell me.
Unread 22-01-2005, 13:56
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Re: Build Error
Well that last message it gave you I think means that there was a syntax error in your program on line 1083 of ifi_picdefs.h. It looks like you are trying to write code for the edubot which I have never done, so thats about all I can tell you.
Unread 22-01-2005, 13:58
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Re: Build Error
Clean: Done.
It looks like its just a syntax error in ifi_picdefs.h on line 1083, just redownload that from Kevin Watson's site.
- from B B frank
Unread 22-01-2005, 17:00
Re: Build Error
The line in red is the first indication of trouble. The COFF is an intermediate file that gets created during the compile. It may be being blocked from creating the file for some reason, maybe file access privledges? The COFF file is called EduCode.cof in the EDU default code folder (H:\C Programming\EDU_Default_02-16-04\EduCode).
Unread 24-01-2005, 18:30
FRC #0302 (Dragons)
Team Role: Operator
Re: Build Error
Got new code, the default runs fine, now I get to kill it. Thanks everyone.
Unread 25-01-2005, 06:12
capenga's Avatar
capenga capenga is offline
Penga boy
AKA: Giovane
#1156 (Under Control)
capenga is an unknown quantity at this point
Send a message via ICQ to capenga Send a message via MSN to capenga
Re: Build Error
I have a little doubt...
I can't compile cause the linker don't find the <stdio.h> (1)
and if I get a <stdio.h> from a common compiler, the linker asks for more two files *.h (2)... and even if I get this two files, then the compiler says that there's a syntax error (3) on the line 174 of <stdio.h> (4)... anyone knows what i could do?
screens:
(1)
Make: The target "R:\FIRST 2005\Programação\2005 code\frc-code-1-12-2005v2.4\FrcCode2005v2.4\main.o" is out of date.
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "main.c" -fo="main.o" /i"C:\mcc18\h" -D_FRC_BOARD -D_USE_CMU_CAMERA -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Make: The target "R:\FIRST 2005\Programação\2005 code\frc-code-1-12-2005v2.4\FrcCode2005v2.4\user_SerialDrv.o" is out of date.
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "user_SerialDrv.c" -fo="user_SerialDrv.o" /i"C:\mcc18\h" -D_FRC_BOARD -D_USE_CMU_CAMERA -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
R:\FIRST 2005\Programação\2005 code\frc-code-1-12-2005v2.4\FrcCode2005v2.4\user_SerialDrv.c:30: unable to locate 'stdio.h'
error 1 spawning c:\mcc18\bin\cpp18
BUILD FAILED: Tue Jan 25 08:51:30 2005
(2)
C:\mcc18\h\stdio.h:13: unable to locate '_defs.h'
C:\mcc18\h\stdio.h:17: unable to locate '_nfile.h'
BUILD FAILED: Tue Jan 25 09:13:02 2005
(3)
Make: The target "R:\FIRST 2005\Programação\2005 code\frc-code-1-12-2005v2.4\FrcCode2005v2.4\main.o" is up to date.
C:\mcc18\h\stdio.h:174:Error: syntax error
BUILD FAILED: Tue Jan 25 09:13:52 2005
(4) this is the line 174 from <stdio.h>
char _FAR *_Cdecl _FARFUNC strerror(int __errnum);
Ignore alien orders.
Unread 25-01-2005, 10:27
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Re: Build Error
Wait... you're trying to use an x86 source file to compile on an 8-bit PIC processor? Yeah, I can see why that might cause some problems. Download the new C18 compiler that Dave talked about at kickoff... it has all the header files you need.
_
Unread 25-01-2005, 15:15
Re: Build Error
Capenga, you are storing your code in a path that is longer then the 60 something characters that the compiler allows. You need to move it to a shorter path, such as: R:\FrcCode2005v2.4
You also need to revert whatever you did to stdio.h, like jgannon said.
Unread 25-01-2005, 18:36
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Build Error
If you don't have it (It's been more than 2 weeks), then talk to someone. I'm sure someone will send it to you for FIRST stuff.
Unread 26-01-2005, 17:03
kutty18 kutty18 is offline
#0234 (Cyberblue)
kutty18 is on a distinguished road
Send a message via AIM to kutty18 Send a message via Yahoo to kutty18
Re: Build Error
I recieved this error message when building...I didn't want to create another thread, so I'm posting it here...
Error - could not find definition of symbol 'getLeftEncoder' in file 'C:\...Robotics\CODE\00_code4\user_routines_fast.o'.
I have the function getLeftEncoder() declared in "encoder.h", and I included "encoder.h" in "user_routines_fast.c". I don't what to do. Any suggestions?
Unread 26-01-2005, 17:39
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: Build Error
Is encoder.c included in your project?
Last edited by Greg Ross : 26-01-2005 at 17:42. Reason: Stupid typo. Asked if user_routines_fast.c were included instead of encoder.c.
Unread 26-01-2005, 17:44
#0234 (Cyberblue)
Re: Build Error
We got it figured out, Thanks.
Where do you actually build your robot and who does the building??? Elgin Clock General Forum 47 14-11-2006 17:50
Who should build the field? Rich Wong General Forum 17 08-03-2006 17:38
MPLab build error Derek t Programming 7 17-01-2005 09:33
MPLAB build error cabbagekid2 Programming 7 12-01-2005 13:36
OCCRA Teams - where do you build? Phil 33 OCCRA 7 28-10-2004 21:41
