Go to Post FIRST is similar to real life in that nothing is perfect and you have to deal with the circumstances as they arise and make the best of it! - Sean_330 [more]
Unread 18-01-2005, 14:14
fleadomofbass fleadomofbass is offline
fleadomofbass has a little shameless behaviour in the past
Maximum Piston Length
What is the max length you can get from first of a pneumatic piston
Unread 18-01-2005, 14:32
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Re: The length of My Rod
check http://www.bimba.com/techctr/first_free_frm.htm see exactly.
but i believe
for 3/4 Bore the max stroke is 10 inchs
and for 1 1/2" and 2" the max stroke length is 24"
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 18-01-2005, 14:38
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
See page 19 of the Pneumatics Manual.
Unread 18-01-2005, 14:39
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
'1-1/2" bore only goes to 11" stroke.
The order form is on the last page of the Pneumatics Manual.
It's at: http://www2.usfirst.org/2005comp/Man...ticsManual.pdf
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Unread 18-01-2005, 16:37
Re: Maximum Piston Length
i was going off the bimba website, which lists upto a 24" stroke length for the 1 1/2" bore size. The last page of the manual says to check the website for available stroke lengths for each bore size.
Unread 22-01-2005, 10:59
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
piston limitations
are there any limitations on the size of the pistons?
Unread 22-01-2005, 12:00
ewankoff's Avatar
AKA: -=The WANK=-
is a 1 and 1/16 inch bore and 24inch stroke piston allowd?
Unread 22-01-2005, 13:21
You have a choice of 3/4" bore, 1 1/2" bore and 2" bore. You can order the amount of stroke you require
Page #7 of the pneumatics manual.
See above for the available stroke lengths in each bore.
Unread 22-01-2005, 18:16
Projectchon's Avatar
Projectchon Projectchon is offline
AKA: William Lei
FRC #1009 (Vainer Robotic)
Projectchon can only hope to improve
Re: piston limitations
for this year,can we use pistons out side of the kit?
Unread 22-01-2005, 18:29
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Please see page 19 of the Pneumatics Manual for all the cylinders and other pneumatic components (other then fitting and tubing) you can use on your 2005 FRC competition robot. <R91> also allows the TI Pressure Transducer and single action solenoid from the 2004 FRC KOP as legal for use this year. But other then those cylinders ["pistons"] on the pneumatics order form for this year, no you can not use cylinders from out side of the 2005 FRC Kit Of Parts.
-Michael Dessingue
Unread 23-01-2005, 06:57
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Re: Maximum Piston Length / piston limitations
Just a note, the order form on page 19 of the pneumatics manual does not list 24" for a stroke length for the 1-1/2" bore, but it also says "Please check the Bimba web site for available strokes in each bore size". Page 7 of the pneumatics manual also says "You can order the amount of stroke you require.", implying you can get whatever stroke you need (of course assuming its avalible). As said by oneangrydwarf the bimba site does list 24" stroke cylinders in 1-1/2" bore, which means you can get it.
Also, rule <R91> says you may use last year's kit pneumatic cylinders and solenoid valves - last year our team recieved two 24" stroke 1-1/2" bore cylinders as part of our 3 free cylinders, meaning we can use these because the rule says any cylinder avalible in the kit last year is also legal this year.
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Unread 24-01-2005, 10:51
Phil Paspalas Phil Paspalas is offline
FRC #1676 (The Pascack Pioneers)
Phil Paspalas is an unknown quantity at this point
Question Limitations on Pneumatic Cylinders.
I've searched this site and read the rules and pneumatics manual over and over again. Can anyone answer this question once and for all?
Can a team use a piston other than the ones offered for free by Bimba? For instance: Bimba make a 1 1/16" dia. piston with a 24" stroke. Is this allowable? I understand that Bimba will only give away the ones listed on their site (3/4", 1 1/2", 2") but if we are purchasing pistons, what range of diameter are we limited to?
Thanks.
Unread 24-01-2005, 11:20
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: Limitations on Pneumatic Cylinders.
This is my final answer - 3/4", 1 1/2" and 2".
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 24-01-2005, 11:23
This question has been answered many times and i will answer it again.
You have the choice from three (3) different bore sizes [piston diameters] to choose from and use this year on your 2005 FRC competition Robot. These three bore sizes are 3/4", 1-1/2" and 2".
Originally Posted by 2005 FRC Pneumatics Manual, Pg. 7
CUSTOM BIMBA CYLINDERS You will again be able to order custom cylinders for your robot again this year. You have a choice of 3/4” bore (diameter), 1-1/2” bore and 2” bore. You can order the amount of stroke you require.
You can find the strokes available for these three bores on page 19 of the 2005 FRC Pneumatics Manual
-Michael Dessingue
Unread 24-01-2005, 11:41
In the spirit of gracious professionalism, Thanks!
Pneumatic's Rules confusion Nitroxextreme Pneumatics 27 03-02-2005 11:16
Using previous years pneumatics? ChuckDickerson Pneumatics 0 30-01-2005 18:22
General Pneumatics Drok00 Pneumatics 8 11-01-2005 23:35
What size monitor do you use? Elgin Clock IT / Communications 30 10-03-2004 16:53
My file size is too big..... JamesWu 3D Animation and Competition 20 20-02-2004 22:31
