Go to Post Wait, we have to be logical? - JaneYoung [more]
Unread 22-01-2005, 12:03
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Encoder Hookup
See the picture on that first page? It says:
1: +5
2: A
3: -
4: B
Farther down the page, there is another picture and a table that reinforces this data. So, hook up two PWM cables to two different digital I/O pins (one should probably be one of the hardware interrupt pins, if you're using Kevin Watson's code). The reds go to pin 1, the blacks go to pin 3. One white goes to pin 2. One white goes to pin 4. On the other page, it shows you which side of the connector is pin 1, so you can identify which wire is which.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Rotary Encoder (optical etc.) Gary C Technical Discussion 4 16-01-2005 18:23
encoder vs. motor stephenthe1 Programming 55 06-01-2005 22:07
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
Choosing an Encoder for the Drive-train MikeDubreuil Electrical 11 21-10-2004 00:50
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
