Go to Post This system sucks more than our ball possession system. - IndySam [more]
Unread 13-01-2005, 09:59
Re: extra connector on breaker panel
The question of the function of the extra connector is answered here: http://www.ifirobotics.com/forum/viewtopic.php?t=165
Unread 13-01-2005, 22:14
cinderblock cinderblock is offline
Team 8 2006 Captain
AKA: Cameron Tacklind
FRC #0008 (PALY Robotics)
cinderblock is an unknown quantity at this point
Send a message via AIM to cinderblock
I looked into the documentation for the breaker panel:
Section 4 of this PDF explains how to use the serial port.
http://www.ifirobotics.com/docs/brea...005-revnc0.pdf
The isometric view in this PDF states that it is an unused connector.
http://www.ifirobotics.com/docs/IFI-BREAKER-INSTALL.pdf
Hope this helped
Unread 14-01-2005, 22:39
Justin_302's Avatar
Justin_302 Justin_302 is offline
Justin
AKA: Justin
FRC #0302 (Mechanical Dragons)
Team Role: Driver
Justin_302 is on a distinguished road
Send a message via AIM to Justin_302
I am confused on how this years breaker works. Last years was VERY simple. They seem to be getting more complicated.
Team 302
Unread 14-01-2005, 22:41
roboticsguy1988's Avatar
roboticsguy1988 roboticsguy1988 is offline
Larry Johnston
AKA: Larry Boy
FRC #1501 (Team THRUST)
Team Role: Electrical
roboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud of
Send a message via ICQ to roboticsguy1988 Send a message via AIM to roboticsguy1988 Send a message via MSN to roboticsguy1988 Send a message via Yahoo to roboticsguy1988
What are you confused about? I can try and help you if you need some. I actually have found it more simple than last years, but thats just me for you .
Larry Johnston, Team THRUST, Team #1501, Team THRUST webpage
2005 IRI - Imagery and Design Award
2005 - 2006 BMR - Professional Grade Award
2006 BMR - Delphi Driving Tomorrow's Technology Award
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~ RogerR
~Da team that uses all tha rivets, Team #1501~
The FIRST Software Repository ~ Chief Admin
openFIRST ~ Project Supporter (Former editor)
DMOZ.org - FIRST - US Teams Section ~ Chief Editor
Unread 15-01-2005, 01:34
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Does anyone, or has anyone, seen a way to detect the current with the new panel? Such as what the robot is drawing at the time. I have a 600 amp shunt which I had a thought about interfacing with the bot and watching the readings even if its just for testing.
-Mike
Unread 16-01-2005, 19:53
Justin,
I think this breaker panel is actually a little easier to use. Problems are sure to arise but I can't anticipate any at this point. After all, there are two more 40 amp breakers than we ever had before and additional smaller breakers plus the added benefit of telling if and which breaker is actually tripping.
The one thing I am concerned about ( and all of you should be as well.) is the soldered in push on tabs. These are not as roboust as last year's breaker panels so they cannot take mishandling. Team members should be aware that pulling at odd angles and wiggling to install or remove the connections may result in breaking the tabs off the board. Once everything is in place and working, be sure to secure all cables so that they do not break the tabs on the breaker panel. Our panel has pretty tight connections on the breakers themselves but I expect those to loosen up with use.
Mike,
In the past we have effectively used a one foot length of #10 to measure current. Search last years' posts for discussions on this subject as there many. A 12" #10 is very close to .001 ohms and using that and a Maxim battery monitor chip seemed to be a pretty easy way to monitor current.
Unread 22-01-2005, 11:19
kutty18 kutty18 is offline
#0234 (Cyberblue)
kutty18 is on a distinguished road
Send a message via AIM to kutty18 Send a message via Yahoo to kutty18
Sort of off-topic, but has anyone weighed the Breaker Panel? We mounted ours to the robot, and we want to know the weight of the Panel? Thanks.
Unread 22-01-2005, 12:22
scifi3018 scifi3018 is offline
scifi3018 is an unknown quantity at this point
So if the extra pwm port can be used instead of the db9 port, this is similar to the connections of the camera this year isnt it?
Digital Breaker Panel Mark McLeod Control System 8 31-01-2005 00:22
Strategies to prevent overcurrent/breaker trip kmcclary Motors 27 28-12-2002 01:00
Keyang Motor Thermal breaker. archiver 2000 1 24-06-2002 00:24
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
