Go to Post "Why yes, actually I AM a rocket scientist" - Gary Dillard [more]
Unread 22-01-2005, 11:45
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Touching carpet under goals
Is there a penalty for a robot part touching the carpet underneath a goal when trying to move a tetra (either in or out)? Is it legal/illegal? Please reference a rule when replying. Thank you in advance.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 22-01-2005, 13:39
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: Touching carpet under goals
I know from a personal conversation with Dave Lavery that robots are allowed to drive in the goals, so it would be plenty legal just to touch the carpet. I will see if I can find a rule and edit this, but I think Dave is probably right.
See you in DC!
Unread 22-01-2005, 19:01
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
Reference Rule G20 in Update02 - that's specifically for touching "under" the goal posts. The goals have velcro that hold them down to the carpet, and the velcro contacts all along the edges of the bottom. So you will get a penalty if you try to go under the edges of the goal stuck to the floor. (Q/A id1169)
But you are in fact allowed to drive through a goal, therefore you are allowed touch the carpet "inside" the goal. Reference the Q/A id1216.
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
Unread 22-01-2005, 19:11
sirbleedsalot's Avatar
sirbleedsalot sirbleedsalot is offline
FRC #0939
Team Role: Student
sirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura about
OK let me get this straight, we can drive over the bottom pipes to go in the goal, but not underneath the pipes that contact the floor.
our web site
Unread 22-01-2005, 19:20
AmyPrib's Avatar
Yes. You can drive over the pipes to drive inside the goal, through the goal, or sit underneath a goal. If you somehow get underneath the pipes that contact the floor, and it's even remotely obvious, you could potentially damage the goal, which is illegal, as it's also illegal to lift, tip, or grab the goal.
I don't think it's too difficult to keep a robot from getting underneath the goal pipes. So hopefully this will not be a problem anywhere. It sounds like the goals are velcroed down pretty good, so it's gonna be a force to get under there and start lifting or damaging the goal in that manner.
2005 Field - Carpet Specs? tribotec_ca88 General Forum 2 14-01-2005 08:27
Are the goals bolted to the floor? Leav Rules/Strategy 1 11-01-2005 03:31
Mobile Goals Joshua May General Forum 12 16-03-2004 10:45
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Stategy Debate: Goals Horizontal vs Goals Vertical archiver 2001 2 23-06-2002 23:32
