Go to Post So we had forklifts in 2015 and now front end loaders in 2017. First has really embraced the industrial side of robotics. - dmorewood [more]
Unread 22-01-2005, 14:17
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: 2005 Team Update #4 posted
Originally Posted by Mr. Van
30 points... three rows... 10 tetras... wow. I guess the point is STAY AWAY from opponents loading zones. I think with 6 'bots on the field, this might be a real issue. What about this situation:
BLUE01 has just capped a goal on the red side of the field. BLUE01 now heads back to its side of the field. As BLUE01 drives down the side of the field, RED01 heads for its loading zone. Contact is made and BLUE01 is in the red loading zone (or pushed into the red loading zone).
From what I understand, blue would receive a 30-point penalty.
How will referees determine if contact was incidental? How will they tell if you were intending to block access to a zone or simply couldn't get out of the way?
How difficult and how much of a risk will it be to travel to the far side of the field?
I could understand the rule and guidelines if the penalty was 10 points, but I believe a 30-point penalty will be just about impossible to overcome - especially if you weren't intending to block a loading zone at all.
-Mr. Van
Coach, 599
I don't see it as such a hard call. Refs in junior high basketball make tough calls all the time. This seems easier than charging calls.
Bottom line, STAY AWAY FROM ROBOTS IN THE LZ.
Finally, I like the examples. I think the intent and the implementation will be pretty clear.
Joe J.
Team #88, TJ2
Unread 22-01-2005, 14:47
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
I'll throw in a little more detail i got from FIRST at kickoff about why such a steep penalty. They are discouraging incidents in the loading zones partially due to it being a personal hazard. At all the Loading Zones, human player or 'automated', there will be people right there while the robots are interacting potentially 'outside' of the field. If a robot has a tetra in their grip on a 6' arm and is hit on the side and winds up hitting the human player or field reset crew member whos loading the automated zone, it can be a very dangerous situation. This should also be pointed out, a 30 point penalty can sway a whole match easily. So its as easy as if a robot is headed to or is in the loading zone, keep away from them, by doing this you will keep all the people around the field safe and keep yourself from being penalized.
This should be one of the rules where we dont ask how will the refs call it if its intentional or not. Thus should be a rule that is taken very seriously and hopefully followed strictly by all teams.
-Michael Dessingue
Unread 22-01-2005, 14:56
O-H
FRC #0048 (Delphi E.L.I.T.E.)
More specifically, stay away from robots in their loading zone who have not yet acquired their tetras. It is imperative that teams do this to ensure the safety of the human players/field attendants. However, once they've obtained a tetra, the human player has returned to his pad (if applicable), and the team wishes to leave their zone, you don't HAVE to let them do so:
Example 6
Robot "RED01" is in the red alliance loading zone, is already loaded with a tetra, and is waiting for a path to clear to the center goal before moving in to the rest of the field. Robot "BLUE01" approaches the loading zone, and blocks RED01’s attempts to leave the loading zone and score on the center goal. The robots come into contact several times while BLUE01 blocks RED01. No penalty is assessed to either alliance, provided BLUE01 acts within the limitations of <G21> that prohibit pinning for more than 10 seconds. RED01 is not retrieving a tetra, so no violation of <G15> has occurred.
So as FIRST currently has defined it, the situation outlined in Example 6 is a valid defensive option for teams. However, I agree with Mike, you better be dang sure humans are safely out of the picture before employing it. If your robot contacts an opposing robot in their LZ that's disabled because their human player hasn't yet returned to his/her pad, you deserve every bit of that 30-point penalty.
Kettering Kickoff Matt Attallah Off-Season Events 19 27-09-2004 22:40
FYI: Team Update #14 is posted Aidan F. Browne FIRST E-Mail Blast Archive 7 03-03-2004 09:05
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
