Go to Post When there appears to be something stupid wrong with a game (HPs outscoring robots, unreliable loading, autonomous that accomplishes nothing) I shouldn't complain about it. I should see it as a challenge to exploit! - Chris is me [more]
Unread 22-01-2005, 14:45
camsrobotics camsrobotics is offline
camsrobotics is an unknown quantity at this point
gearing problem. Help please!
We're running very light on mentors this year, so if you guys could help us out with some advice it'd be much appreciated.
we stole the CIM motors from drive team (2) so that we could have the high torque motors to lift tetras at the end of a long arm. The CIM motors run at 5000 some odd RPM and we are trying to gear them down to about 10. We cant find transmissions that would fit our CIM motors. If anybody knows where to find transmissions that would work with the CIM motors, please let us know.
Does anybody know if we can still use the Van Door motors?
Thanks so much,
687 Articulation Team.
Unread 22-01-2005, 15:28
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: gearing problem. Help please!
Yes you can still use the Van Door Motor from Taigene that is in the kit.
As to a 500 to 1 gearbox with the Chiaphuas as input, this is going to be tricky.
10 RPM is mighty slow.
But if you insist on such a high reduction, I recommend using some sort of Jack Screw for the last stage. You can get relatively effecient ones with ball nuts. If you try to go with a straight spur gear gearbox, you are really going to have to beef up the last several stages. 1000N-m (2000N-m if you use 2 Chiaphuas) is a LOT to deal with, requiring very strong gear teeth.
Joe J.
Team #88, TJ2
Unread 22-01-2005, 15:32
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
In My Humble Opinion:
CIMs are much more suitable as drive motors. Use all four of them! For your arm, use the window motors, which have worm gears inside so they won't backdrive (easily). If you need a third pivot point, use the van door, but it's worm gear is significantly easier to backdrive.
CAVEAT: I'm a programmer, and this is all regurgitated information from our chief gearhead.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 22-01-2005, 16:20
jrocket567 jrocket567 is offline
FRC #0617
jrocket567 will become famous soon enoughjrocket567 will become famous soon enough
I'd give those CIMs back to the drive sys (I did the drive sys for my team and i made sure that I had all 4, so i mght be slightly biased).. If you need a gear reduction that big- the easiest thing to do is a worm gear- they have one heck of a reduction and will not back-drive....good luck
j
Unread 22-01-2005, 16:54
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
You can definitely get the Andymark gearboxes to use which can be found under the product section of www.andymark.biz ... if you feel the need of more help, feel free to send me a message and I would go over a few process that you would need to go through with you in order to make your own gearbox. Good luck.
-Arefin.
Unread 22-01-2005, 16:59
Unless you are trying to pick up 2 or more tetras on a >5 ft arm, you wont need these motors. 2 Fisher price motors would actually give you more than enough power, and all you need is a 10:1 chain and sprocket reduction. You could also probably use van door... or maybe even Globe)
Moral of the story.. give those CIMs back!
Unread 22-01-2005, 17:10
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
If you use 2 of the KOP gearboxes in tandem, they are designed to handle the load of 1 chip motor.
This "double stack" will give you a reduction of:
14/50
14/50
14/50
14/50
= 1:162ish
From here you are a simple #35 chain reduction away from 500:1
(10:30 in chain gives you 488:1 overall)
Disclaimer, this setup can handle ONE CHIP MOTOR ONLY. If you run 2, you are toeing the line. But... honestly... with one chip - the stall load on a 4 foot arm is 130 lbs. Do you really need any more torque?
For more information on the "double stack" transmission, refer to the "FIRST 2005 Transmission Manual-RevB" found here:
http://www.ifirobotics.com/kitbot.shtml
Good Luck -- feel free to ask questions about this feedback,
Thanks,
John
Unread 22-01-2005, 17:12
cadman2k5 cadman2k5 is offline
AKA: steve lami
#0637 (Horsepower)
Team Role: Student
cadman2k5 is on a distinguished road
Send a message via AIM to cadman2k5
Don't forget about a worm gear reduction system. May use up some weight really quickly, but you are using a cim. My team's rookie year we had to do something like that. used a 25:1 at max gear reduction. I was only told about it but it worked. My suggestion would be to use a window motor instead, it doesnt rotate as fast and gear reduction should be a snap.
Unread 22-01-2005, 20:06
occra 23.
AKA: ryo
None #1481
worm reduction or harmonic drive
http://www.globaltec.thai.com/sub2/sub2c.htm
Unread 22-01-2005, 20:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
And for the kit gearboxes, don't forget you may be able to use an AndyMark Planetary and a fisher price instead of the CIM. Your outpur speed will be a little higher.
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
