Go to Post that is one of the funniest non-photoshoped pictures of my father i have seen... - Lil' Lavery [more]
Unread 22-01-2005, 10:45
Jakenan Jakenan is offline
AKA: Jacob Rojas
FRC #0457 (Grease Monkeys)
Jakenan is an unknown quantity at this point
Can anyone create new commands?
Im new at C and is slowly figuring it out. I learned how to use the current commands and is wondering if it is posible to program new commands. Man i have to go to a meeting soon, so if some one can help that would be great and i will be sure to read and express my thanks when i get back.
Unread 22-01-2005, 11:11
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: Can anyone create new commands?
What do you mean by 'commands?' Are you referring to functions? Or are you referring to the autonomous program provided by FIRST? If you're talking about built-in functions, then you certainly can! The basic format of a function is this:
(replace the items in square brackets with the proper keywords)
[returntype] [functionname]([argtype1] [argname1],[argtype2] [argname2]...){
/*Your code here*/
return [result];
For example:
double squareit(double numberToBeSquared){
return numberToBeSquared*numberToBeSquared;
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 22-01-2005, 17:47
AKA: Jacob Rojas
No, in the command.h and .c files are a list of...functions, or commands*not too sure* that say: COMMAND, parameter1, parameter2, parameter3. I guess i dont understand how the commands are created and how to create my own commands and set parameters to them. if any one can, please help...
Unread 22-01-2005, 19:29
ahmed ahmed is offline
synOrange
#0843 (White Oaks Wildcats)
ahmed is an unknown quantity at this point
Send a message via AIM to ahmed Send a message via MSN to ahmed Send a message via Yahoo to ahmed
What you are refering to sound much like what steven114 just explained
Unread 22-01-2005, 20:20
I think he's talking about the default autonomous code, which is different. I have not used it, so I don't know.
Unread 22-01-2005, 21:38
iscrc2 iscrc2 is offline
#0568 (Nerds of the North)
iscrc2 is an unknown quantity at this point
yes you can 'define' new commands to place in the command.h
in robot.h around line 169 insert new lines that name a command and give a function prototype
in robot.c around line 156 insert new lines that will act on the new command
(it would look almost exactly like the CMD_KEEP_HEADING block just before it)
at the end of robot.c add the function you gave a prototype to in robot.h
(you might use the command state structure the other commands use: START, IN_PROGRESS, COMPLETE) don't forget to return a 1 else it will get stuck on that command.
Then you can use your new command in the command.h 'script'
Multiple command_lists Jon236 Programming 8 20-01-2005 17:55
How should I create a database of real estate? :) Ryan M. Website Design/Showcase 9 09-08-2004 15:27
how to create custom interface _GP_ Technical Discussion 1 18-01-2004 21:24
Create a Game Details Katherine General Forum 7 06-09-2003 23:44
Voice Activated commands Amber H. Technical Discussion 40 03-11-2002 12:40
