Go to Post One thing that FIRST has given me ... Friends who care. - Arefin Bari [more]
Unread 21-01-2005, 02:13
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: Front wheel steering VS. 4WD
Originally Posted by Denman
the only problem with 4 wheel drive is your more likely to get stuck against a wall or something straight...
How can you get stuck against the wall? The only way you could if you intentionally tried to get wedged under something like the arena wall, but that would totally take out the arena wall too...That would be insane.
But o well, I might be wrong.
Unread 21-01-2005, 14:49
Evan Austin Evan Austin is offline
out of my mind, be back later
Evan Austin is an unknown quantity at this point
If you really want a 2wd, you could use two small omni wheels or casters on the front (or rear) of your robot and drive like a normal tank drive. We did this in the past and it did work well, you just don't have as much pushing power as a 4wd would. However, it should be lighter than a 4wd too, and still be fairly maneuverable.
I would not use a car type steering on a robot because of the limited area in which the robot must operate. It could be done, but I think that it is more trouble than it is worth.
Unread 21-01-2005, 20:41
Kelvin Ng Kelvin Ng is offline
None #1558 (ACCIDENT Robotics (Albert Campbell Collegiate Institute stuD)
Kelvin Ng is on a distinguished road
yeah our team is planning on using 2WD instead of 4WD. If we don't use casters nor car steering, what is a good substitute?
Unread 21-01-2005, 20:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I assume you are having four wheels, with two driven. I would suggest making the driven ones really high traction and the non-driven ones fairly low traction.
Unread 21-01-2005, 21:16
jrocket567 jrocket567 is offline
FRC #0617
jrocket567 will become famous soon enoughjrocket567 will become famous soon enough
were using 2 driven wheels, and dropping the casters and replacing them with teflon skids..something really slick..
j
Unread 22-01-2005, 20:53
in response to skids or low friction wheels, how about omniwheels? i found out what they were and how they worked yesterday and i am quite amazed. secondly are those wheels expensive? we don't have any sponsors yet and living off our science department at the moment.
Unread 22-01-2005, 22:38
occra 23.
AKA: ryo
None #1481
yea, they can be slightly expensive. but you can attempt to make your own. well, we havent had much luck in that since we have only a drill press... without a turntable or w/e you call it.. but yea. ball transfers work too. and teflon. nylon maybe? ummm yea, omniwheels are nice...
Unread 22-01-2005, 22:39
Mike33's Avatar
Mike33 Mike33 is offline
NOOOOOOOOOO! MY LAST YEAR IS OVER!
AKA: Keebler (Elf)
FRC #0033 (Killer Bees)
Mike33 will become famous soon enough
Send a message via AIM to Mike33
If you wanna go 4WD, my team made a 4-speed tranny last year. the CAD drawings should be posted on www.ndprep.org/robotics. With a little coding, we made this into an automatic transmission. 4WD has its plus sides and its minus sides. You have to decide depending on your strategy and/or your tetra manipulator. But I would go for the 4WD. There's gonna be alot of traffic on the feild.
--"Always bear in mind that your own resolution to succeed is more important than any other one thing." --Abe Lincoln
Final Four in 2005 National Championship
2005 National Team Imagery Award
2005 West Michigan Imagery Award
2005 Detroit General Motors Industrial Design Award
2nd Place in Detroit and West Michigan
"Its a jeep thing, you wouldn't understand"
---copy the jeep and pass it around---
o_o_o_o
./| ,[_____],
|ŻŻŻL--O|||||||O
()_)Ż()_) ŻŻŻ )_)
(originaly made by my friend david)
Unread 22-01-2005, 22:45
Projectchon's Avatar
Projectchon Projectchon is offline
AKA: William Lei
FRC #1009 (Vainer Robotic)
Projectchon can only hope to improve
4wd is better, but it depens on how you drive it, a 4WD's turnning Axie is near the center, but if you are doing F2WD your turning axie will be near the front, that means your turning axies is near the middle between your armand your robot (like a forklift).
Team 1009
Unread 22-01-2005, 23:07
Eric Yahrmatter's Avatar
Eric Yahrmatter Eric Yahrmatter is offline
Eric Yahrmatter has a spectacular aura aboutEric Yahrmatter has a spectacular aura about
4 wheel drive, combined with a multiple speed transmission, will supply a robot with enough torque in low gear to push just about anyone. In high gear, you then can have high straight-line speeds, but the turning can be difficult.
Unread 24-01-2005, 20:11
Vash's Avatar
Vash Vash is offline
The Humanoid Typhoon
#1318 (Issaquah Robotics Socitey)
Vash is on a distinguished road
If you wanted to get creative with slippery skids you could use something like a half sphere of teflon in place of a castor. Also if you did use two wheels to drive you could replace the wheels to increase traction.
Love and Peace
http://www.issaquahrobotics.org
Unread 24-01-2005, 21:16
Bleric's Avatar
Bleric Bleric is offline
#0624 (CRyptonite)
Bleric is on a distinguished road
Send a message via AIM to Bleric Send a message via MSN to Bleric
Yes, chalk up another vote for teflon skids / omniwheels. (For a 2wd robot, that is) Casters DO have a tendancy to make the robot drift to the left or the right.
Besides, omniwheels look SO cool
Steering wheel problems jgannon Programming 4 16-01-2005 14:25
Steering wheel issues jgannon Programming 5 15-12-2004 10:14
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
4 wheel steering/ Crab Huey_Da_X-cat Technical Discussion 3 11-02-2002 22:49
