Go to Post "The audience will be making three sounds this year: oos, aahs, and oh my God, watch out!" - nate234 [more]
Unread 22-01-2005, 08:32
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Problem running compiled code
When we make any change to the default source code, compile it, and upload it to the robot, it will not run. The robot controller just hangs, with lights flickering on and off. The upload seems to go properly, with the correct acknowledgement messages etc.
When we upload the unmodified default code, everything works properly (except that the robot complains that it cannot find the camera), so the connection between the computer and robot works just fine.
We are using the latest version of the C18 compiler.
Any ideas?
Unread 22-01-2005, 10:07
Re: Problem running compiled code
It's really hard to know what "any" change is. Can you give examples?
Unread 22-01-2005, 11:38
None #0612
... adding a comma to a comment line causes this problem.
It would appear that the compiler is not producing operable code, even though it gives no error messages.
Unread 22-01-2005, 13:34
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
I was actually having the same trouble, except that I assumed that the problem was because I was using WINE under Linux. Maybe it's not WINE's fault...
Has anyone gotten the new 2.4 compiler to work?
jskene: Could you post a md5sum of the .hex file that the linker produces without any changes to the code? I want to see if we get the same output...
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 22-01-2005, 16:33
Most problems of this sort that I've run into have been due to installation mistakes, diverging from the installation defaults, or reordering/relocating folders. For instance, the MPLAB toolsuite setup.
Unread 22-01-2005, 19:56
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Yes, I have the new compiler working 100% correctly.
(O:\Source\FIRST\FrcCode2005v2.4) md5sum FrcCode.hex
9d4c589d007f4f1df0cd8ca0eb634269 *FrcCode.hex
Unread 22-01-2005, 21:29
Ralph Lambert Ralph Lambert is offline
Mentor - Team 1094
None #1094 (Channel Cats)
Ralph Lambert will become famous soon enoughRalph Lambert will become famous soon enough
We are having exactly the same problem as jskene.
Unread 22-01-2005, 21:37
Double-check to make sure you've selected the correct target device. If you're accidentally compiling the code for something other than a PIC18F8520, it won't run on the RC.
Unread 22-01-2005, 21:38
Back after 4 years off
FRC #5279
I had a problem on my home computer, however I re downloaded and installed the compiler at our office where we do or work and it compiles downloads and runs fine I would say do a full un install and then start over, It can't hurt to try
Unread 23-01-2005, 21:11
agentfat2004 agentfat2004 is offline
agentfat2004 is an unknown quantity at this point
I have the same problem with my controller.
Simple as declaring a variable messes with the controller. Writing a code works until the controller is reset or powered off. Then the program state gets messed up
Unread 23-01-2005, 21:13
Hmm. Apparently it only happens on the EDU controller for me. The full-sized one works great.
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
Some Blank Code That you Know works chantilly_team Programming 5 18-01-2005 22:00
Strange IR sensor movement with default tracker code wun Programming 5 19-03-2004 10:51
One final fairly massive problem with the code... authgeek1218 Programming 5 19-02-2003 16:51
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
