Re: Why is the kitbot chassis bowing in horribly
there are no problem with our chassis too, but there are some rought sound when we run the motor (w/gearbox).
we did put grease on it, i'm not sure what type (not WD-40), is a blue jelly colored grease from motormaster
same thign has happened to us~ we cut some angled aluminum brackets to give some extra support
how quite is your jelly-filled gearbox? how tasty? -Leav |
Problem was solved. I think they mounted the top bar to tightly and forced it on like that. It is now a nice looking chasis from which we shall practice driving with.
#7
Did lithium grease come with the kit? If so, what does it look like ? =/
#8
No sorry, it was not included in the kit. You should probably pick up a tube at your local hardware store
#9
You can also find lithium grease in your local autoparts store and auto sections of Kmart, Walmart and other similar stores.
#10
Noise in the KOP gearbox is also do to the fact that the retaining rings on the motor shafts grind on the second 50T gear. If you open the gearbox after you've run it under power you'll see a groove in the gear. The ring is harder and will cut away at the gear, robbing you of power and make a horrible sound. Try carefully grinding the diameter of the retaining ring so it clears the the gear.
| KOP Chassis & Transmission Support/Documentation | JVN | Technical Discussion | 0 | 10-01-2005 00:28 |
| the provided chassis material | Andrew Dahl | Kit & Additional Hardware | 5 | 09-01-2003 15:26 |
