Go to Post I'm not suffering from my FIRST "addiction". I enjoy every minute of it. - Katie_UPS [more]
Unread 22-01-2005, 19:25
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Importing Inventor Into 3ds max?
Okay... so I found out how to import an Inventor file but it takes forever and then it's really slow. Then I saved it (second time trying, first w/o my computer freezing) and now I can't open the 3DS Max scene. Am I doing something wrong? Or is there something wrong with my computer? Also, I would do this with VIZ but I can't get VIZ to start up (whole other thread). If you can help... please do.. if you can't then I will just model the robot in 3DS Max, it will just take a little longer. Thanks in advance.
Budda
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 22-01-2005, 23:57
SteveC116's Avatar
SteveC116 SteveC116 is offline
SteveC116 has a spectacular aura aboutSteveC116 has a spectacular aura about
Re: Importing Inventor Into 3ds max?
I've had some bad experiences getting Max and Inventor working together. The easiest way to get an Inventor file into Max is to export it as an IGES file. The only problem with that, is the geometry gets messed up if it's too complicated.
The problem with Max behaving really slowly is most likely because you just ran Inventor. Running Max and Inventor at the same time can cause major speed problems in Max. Sometimes, when you close Inventor, it doens't actually close. Check your processes in the task manager to make sure that inventor.exe actually shut down.
Finally, there is an easy way to merge a normal Inventor part or assembely into Max without importing or exporting to different file formats. In your BIN directory for Invetor there is a file called LoadInventorImporter.ms. Copy that file into your scripts\startup directory for either Max or Viz and restart the program. You will now be able to use "Merge" from the file menu to import Inventor files.
*Guarana Induced Happiness*
Steve Cohen
Team 116 Animation Captain
http://stevecohen.blogspot.com
Unread 23-01-2005, 00:07
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
The reason it is slow is because the polygon count on the IGES models is VERY high. Normally what I do when I import .IGES files into Max, I will use the "Optimize" modifier. This will cut out unnecessary polygons in the model. It takes a little bit of playing with to understand how much to optimize by the model, but it can help a lot. If you optimize it too much, it will start to take out the important polygons on the model and will distort the geometry.
Eric
Unread 23-01-2005, 11:53
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Thanks.
Do The Tyler!
Unread 23-01-2005, 14:16
andrew.kintz andrew.kintz is offline
andrew.kintz is an unknown quantity at this point
This has been most helpful. Thank you
Unread 23-01-2005, 15:15
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Alright... I tried this but everytime I select the Optimize modifier Max freezes and stops responding. Is it my computer? Is there anyway to lower the poly count in Inventor? It would be much easier to save a lower poly count project from Inventor then import it to Max. That way I wouldn't have to deal with a p.o.s. computer.
Thanks.
Budda
Do The Tyler!
Unread 23-01-2005, 18:20
SteveC116's Avatar
In my experience with direct importing (using the process I described), the models are lower polygon and do not slow down the computer.
Steve Cohen
Unread 31-01-2005, 19:42
kcy88's Avatar
kcy88 kcy88 is offline
Animator
AKA: Kevin
FRC #0075 (Roboraiders)
kcy88 is a jewel in the roughkcy88 is a jewel in the roughkcy88 is a jewel in the rough
Send a message via ICQ to kcy88 Send a message via AIM to kcy88
Are you using 3DS Max 7?
Is it necessary for both 3DS Max and Inventor to be installed on the same machine?
What I did was copy the InventorUtility_Max6.dlu and InventorImport_Max6.dli to the Max Plugin folder and ran the latest LoadImporter.ms script.
I get an error message saying that it cant find the specified dll module.
And I'm pretty sure I had the directory changed corectly in the maxscript.
Team 75 - Roboraiders
Hillsborough High School Robotics
2006 Boston Regional Autodesk Visualization Award
2006 Boston Regional Engineering Inspiration Award
2006 New Jersey Regional Engineering Inspiration Award
2005 New Jersey Regional Autodesk Visualization Award
2005 Duel on the Delware champions
2005 Brunswick Eruption 4 champions
Unread 31-01-2005, 21:30
ebmonon36's Avatar
Thanks.
Budda
With a slower computer, the Optimize modifier can take some time and I believe that is what is happening. If you are importing large assemblys, this will slow it down a lot. When I did it, I did it by individual part, and the ones that were still to high and I could model or simple enough that it wouldnt take too long to model, I would. As for exporting low poly objects, I do not know if that can be done as I do not know a lot about Inventor.
Eric
**FIRST EMAIL**/Gear Up with Live Inventor and 3ds max Trainings! Billfred FIRST E-Mail Blast Archive 0 22-12-2004 16:30
Importing inventor files to 3ds max.... I found it!!!!! Tyler Olds 3D Animation and Competition 0 21-01-2003 19:16
3ds max VS Maya VS XSI DisTurbed 3D Animation and Competition 7 08-08-2002 22:52
Text effects in 3DS Max... Ranma 3D Animation and Competition 6 28-02-2002 21:56
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
