Go to Post Don't let my students know I skimmed that blog and didn't read it thoroughly. - rlance [more]
Unread 23-01-2005, 01:23
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Re: Motor Placement Pros and Cons
Hi Pattie,
Let me offer my POV on this..
are you guys going to use this as a direct drive to one wheel on each side??
If so, it might be worth your while, bit the instant you try and turn, you will be doing donuts easily. my advice is mirror your robot, make each side symmetrical, it makes for much better weight distribution as well as power effeiciency.
One mroe thing, in that current setup, you will also have some frame warp, this will happen when your robot goes to pick up something and your left wheel is trying to get traction and the other is going to be slipping (kinda the same as a posi-trac rear end)
all in all a forum is merely a tool for suggestion, and we utterly cannot swing a teams vote...
good luck!
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 23-01-2005, 12:55
Pattie Pattie is offline
Pattie will become famous soon enough
Hi Greg,
Thank you for the comments. This helps. I had never heard of a setup like this before and wondered if any other team had tried it or considered it. No direct drive was in this latest plan. I have visions of the the chassis moving diagonal. But I know I am biased from a programmer perspective - hoping this approach doesn't make the chassis veer off to one side or making one turn difficult that we have to get creative modifying code to make up difference for - so asking for other input. I really appreciate everyone's responses on this. I'm looking for the pro that makes this approach worth taking the risks. My concerns may be total nonissues. But warp on the frame is a big concern. This helps a lot.
Pattie
Unread 23-01-2005, 16:28
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
My team had a design like this at one point. The main advantage that this design has is that you open up the middle of the robots chassis so that wiring and placement of other components is much simpler because you do not have to run wire and hose around the motors in the middle of the chassis. However, the electrical team captain and I (Programming, and pneumatics captain) designed this.
Unread 23-01-2005, 16:38
Hi Cyberwolf. Thanks for the response. You say you had this design at one point - what were the reasons you did or did not use this design? Were there any fatal concerns with this design?
Pattie
Unread 23-01-2005, 16:42
AKA: Allen Gregory
The reason we eventually decided against it was that we were going to go with a 6-wheel drive train if the chains connecting the wheels broke we wanted out center wheel to stay powered so in the end we decided to put the motor in the center of the robot. In addition, it put the weight above our center wheels.
Unread 23-01-2005, 20:00
occra 23.
AKA: ryo
None #1481
well just an imput from a lego stance, i have used this in many lego models with much success. but lego is slightly different as most of you know. why i used it in lego, because haveing them in that config allowed me to leave the minimum width to 5 blocks rather than 10
Unread 24-01-2005, 01:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I didn't take a look at the word document, but because our gearboxes are so large we are placing one at the front right wheel and one at the back left wheel. Not optimal but functionally the same.
Unread 24-01-2005, 11:21
Have you had any issues with driving crooked at all?
Practicing after Ship - pros & cons Natchez General Forum 24 18-01-2005 23:06
Team 871 - Homebrew Segway MrB General Forum 140 06-07-2003 16:21
Timing belts pros and cons!!!! archiver 2001 3 24-06-2002 00:33
Buckeye Regional PROS and cons emilywll Regional Competitions 14 18-03-2002 10:04
